car wont start?
Old Jun 21, 2002 | 06:41 AM
mattL's Avatar
Default car wont start?
hi guys my girl has a 92si, and recently its been acting up a bit. once in a while when you go to start it theres nothing there, it just clicks once and doesnt even turn over. if you give it a minute and keep trying it eventually starts up fine. I'm not sure what it could be, i'm gonna replace the cap & rotor, but does anyone have any idea what it could be? thanks
Old Jun 21, 2002 | 07:22 AM
96_GSR's Avatar
Default Re: car wont start? (mattL)
Check the starter solinoid. May have a bad starter or worn brushes..Maybe bad contacts as well..
Old Jun 21, 2002 | 08:53 AM
flymecourageously's Avatar
New User
check your battery.just even though the lights on instrument panel go on doesn't mean battery is good check the obvious first
Old Jun 21, 2002 | 09:40 AM
Dutchie's Avatar
Default Re: car wont start? (flymecourageously)
Ya, the battery and posts should be the first thing you check. Also, check the wiring to the starter. That was happening to me and all I had to do was recrimp the wire to the starter.
Old Jun 21, 2002 | 09:52 AM
mattL's Avatar
Default Re: car wont start? (Dutchie)
true, i'll check it out. whats the best way to check a battery? i dont think its the battery cause it cranks up strong, just sometimes its tottaly dead so a loose connection or bad starter seems more like it
Old Jun 21, 2002 | 12:01 PM
dphi's Avatar
Go to Advance or Autozone or whatever and get the free charging system check. That would be a good place to start.
Old Jun 21, 2002 | 12:19 PM
Dutchie's Avatar
The connection to the battery is what I was talking about. Probably a bad wire, ground, or most likely the clamp. My old car did the same thing until I slid a carpenter nail in between the clamp and the post.
Old Jun 21, 2002 | 12:23 PM
mattL's Avatar
alright, i'll check it all out, thanks for the help
Old Jun 23, 2002 | 01:20 AM
QTKEG6's Avatar
i vouch for a faulty ignition switch cause thats what happened to me
Old Jun 25, 2002 | 07:33 PM
mattL's Avatar
Thanks for your help guys, replaced the starter and she cranked right up heres the weird part though, it looks like it had a B series starter in it. guess theyre compatible
2DoorBandit
15
Jul 20, 2011 03:54 PM
dohcgarage@714
Mar 18, 2007 06:50 PM
Lsgsr94
Jan 8, 2007 08:38 PM
lazykiwi
Nov 27, 2004 04:17 PM
liquid51
Jun 29, 2003 11:56 AM
