strange tranny problem
Old Oct 17, 2003 | 06:39 PM
743 Stunna's Avatar
Default strange tranny problem
I have a 94 integra ls with a jdm gsr tranny. After I got it installed, you have to push the shifter off to the right like 2 inches to get it into every gear. There's massive amounts of slop when in gear. Appx. 4 inches side to side in gear. It stays in gear and goes in gear fine, but everything is off to the right. We checked the linkage and stabilizer for tightness and its all tight. The shifter (aftermarket) is installed properly on the linkage. Could the wrong linkage or stabilizer be installed? Could it be an internal tranny problem?
Old Oct 17, 2003 | 09:22 PM
743power's Avatar
Default Re: strange tranny problem (743motorsport)
help us out here!
Old Oct 18, 2003 | 07:52 AM
pro1342's Avatar
Could be wrong or bent.....
Old Oct 18, 2003 | 08:27 AM
T4eg's Avatar
Default Re: (pro1342)
i would say its bent
Old Oct 18, 2003 | 11:42 AM
743power's Avatar
Default Re: (BlueHatch00)
Bent linkage wouldnt explain the massive slop in the shifter when in gear though. Any other ideas?
Old Oct 18, 2003 | 12:10 PM
Mochanic's Avatar
Default Re: (743)
loose or torn bushing on the bottom of the shifter?
bent shift forks inside tranny?
Old Oct 18, 2003 | 12:25 PM
743power's Avatar
Default Re: (Mochanic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mochanic &raquo;</TD></TR><TR><TD CLASS="quote">loose or torn bushing on the bottom of the shifter?
bent shift forks inside tranny?</TD></TR></TABLE>
All the bushings are new, all tranny seals and bearings are new. It does the same thing for every gear including reverse, so I doubt it's the shift forks.
Old Oct 18, 2003 | 07:21 PM
SANKA's Avatar
Default Re: (743)
help
Old Oct 19, 2003 | 09:58 AM
743power's Avatar
bump for some tech
Hephro.T
Sep 27, 2016 11:22 PM
insidious408
May 26, 2006 11:48 AM
TylerC
Nov 16, 2005 05:29 AM
743power
17
Oct 25, 2003 06:04 AM
nY's FiNeSt
13
Jul 1, 2003 11:52 AM
