problem shifting on new build
Old Feb 26, 2007 | 10:50 AM
dartdc97's Avatar
Default problem shifting on new build
i cannot downshift into 4th. i had this itr tranny in my last car before it was totaled, and it shifted perfect, no grinds. it does not grind, the gears mesh well, only the problem is it wont go into 4th when downshifting. i have to double clutch from 5th to 3rd, and from 3rd it goes in to 4th fine. shifting up is no problem either, but i can feel a little more resistance when i upshift into 3rd and 4th also, so i know those gears are the problem. i also know that the shifter being used is different, (used to be dc short throw on old car, now skunk2) and i know the linkage is different( old was 97 dc2 b series, now the linkage is from older 94 dc). this car is older, its a 94 ls. i was wondering what the culprit could be and what i should check before i buy a new shifter, linkage, or bushings. would worn bushings cause a problem like this? could it be the linkage? the whole shifter just has more play in it than i would like. i want it to be tight, so what needs to be changed? any thoughts are appreciated.
Old Feb 26, 2007 | 10:54 AM
dartdc97's Avatar
Default Re: problem shifting on new build (dartdc97)
and sorry mods, the build is on a newly boosted car, i know the F.I. guys are knowledgeable on many troubleshooting issues. i asked this question on the integra and misc/tech forums with not one reply.
Old Feb 26, 2007 | 12:05 PM
Mr.60trim's Avatar
From: What Business is it of yours where Im from Friendo
Did you install a new clutch as well?
Old Feb 26, 2007 | 08:33 PM
dartdc97's Avatar
Default Re: problem shifting on new build (Team_Carnage)
yeah. i went from an exedy street disc setup to an act six puck. i didnt install the clutch myself.
Old Feb 26, 2007 | 09:32 PM
zexxbo's Avatar
its possible that the linkage or the part the linkage connects to on the tranny (what shifts through the gears) got slightly bent during your car getting totalled..
Old Feb 27, 2007 | 10:46 AM
dartdc97's Avatar
Default Re: problem shifting on new build (zeimbo)
damn. that would suck. i really cant even check it out just yet because of the damn weather here.
Old Feb 27, 2007 | 11:21 AM
93supercoupe's Avatar
I would say replace the stabalizer bushings and change ur fluid
Dr Blood
May 10, 2006 03:42 PM
AzntstyleZ
Jan 12, 2004 09:37 AM
