cant do timing!!! help!!!!
Old Jul 10, 2003 | 11:13 AM
mattcalica's Avatar
Default cant do timing!!! help!!!!
okay, i am trying to fix my timing, because it is faaaar advanced, but i cant find the pointer on the block. i think mine might have gotten scraped off or something, because there is nothing on my block cover!!! i see the marks on the crank pulley, but i dont know what to line it up with!!! please somebody help. if you have a pic of where the pointer should be, or something that i can line the marks up with, that would help a lot!!!!
Old Jul 10, 2003 | 02:24 PM
Diablo Tejano's Avatar
Default Re: cant do timing!!! help!!!! (mattcalica)
You just have to rotate the bottom end until cyl #1 is at TDC, then align the timing marks on your cam gear(s), slip on the timing belt and you're done.
BTW: The easiest way to find TDC is to pull the #1 spark plug and slowly lower a long screwdriver into the cylinder MAKE SURE YOU DON'T HIT THE CYL WALLS then rotate the bottom end until the screwdriver is at the top of its cycle. Bam, TDC.
James
Old Jul 10, 2003 | 02:33 PM
orange.honda's Avatar
Default Re: cant do timing!!! help!!!! (bluboy)
hey i got this but i dont know if it will help.
Old Jul 10, 2003 | 02:59 PM
Default Re: cant do timing!!! help!!!! (orange.honda)
Yeah, that diagram is the basic idea that I was trying to convey. If you can see the key behind the crankshaft pulley bolt just make sure that is @ 12 o'clock. That will put cyl #1 at TDC.
James
Old Jul 10, 2003 | 06:47 PM
IN VTEC's Avatar
It's not likely to have gotten the ignition timing reference mark ripped off. The mark is right around 12:30, just above the crank pulley and just below the timing belt tensioner bolt plug.
If it did get sheared off, then you need to get a new lower timing belt cover. I can't think of any way to fabricate and accurately reference a new pointer.
We are talking about ignition timing and not cam timing, right?
tpnorth
Jul 18, 2011 07:30 PM
volcomstoned805
Jun 7, 2009 09:31 PM
hondakevin21
Jan 21, 2009 07:42 PM
d16trex
Jul 17, 2008 11:04 AM
1bar_ek
Jun 9, 2005 06:12 AM
