Can you change a cyp sensor ???
Old Feb 13, 2008 | 04:33 AM
Si2See's Avatar
Default Can you change a cyp sensor ???
Hey guys, I am working on a obd1 d16z6 swap in my 91 hatch. My distributor started popping a cyp sensor CEL. So I bought a used distributor off a member on h-t and and it is no good. The bearing is bad, but there is no cel now with this distributor for the cyp sensor, so my question is can I switch them out and if so how?
Old Feb 13, 2008 | 05:09 AM
Mikey3000's Avatar
Default Re: Can you change a cyp sensor ??? (Si2See)
no i dont believe you can switch out the sensor alone. you'll need a good distributor.
Old Feb 13, 2008 | 04:55 PM
slowcivic2k's Avatar
You can dismantle the distributor to replace the guts IF you have another spare distributor that will not fit. It's not very often I hear of those sensors going bad, so check your wiring first.
I successfully transplanted the sensors from a D16Z6 distributor into a B16A distributor case, so I know it can be done, the sensors are somewhat universal.
Old Feb 13, 2008 | 06:24 PM
likwidchz's Avatar
its possible all the cyp sensor is is a switch activated by a magnet, take it apart and let us know.
Old Feb 14, 2008 | 04:26 AM
Si2See's Avatar
I have two spare d16z6 distributors. One is gone but it has a good cyp sensor, the other one the bearing is fine but it has a cyp sensor code, and I have had it apart but am not sure which one is the cyp sensor
Old Feb 14, 2008 | 11:00 AM
likwidchz's Avatar
Well..
B11---orn3----------CYP
B12---wht-----------CYP
According to obd1 pinouts, so take it apart and figure out where the wires go inside the distributer.
think outside the box a little
Old Feb 14, 2008 | 11:02 AM
Si2See's Avatar
that is the information I needed thanks
Old Feb 14, 2008 | 11:29 AM
Bull_head360's Avatar
not to hi-jack the thread, but I also get that CEL, does anyone sell just the sensor?
Old Apr 16, 2008 | 03:19 PM
EquipedWithVtec's Avatar
umm yeah i have 2 distributors also and all of a sudden its throwin a code p1381 i swapped out to the 2nd distributor and still the same and when i start my car if i dont give it gas it will stall i need help i have a d16y8 i dont have alot of money and dont want to spend alot to fix it so if anyone nose where to start looking at the wiring tell me please.
Old Apr 17, 2008 | 04:43 AM
Si2See's Avatar
when i made this thread, i was asking if I could do it so I would have a good backup distributor. if you are getting this code, more than liklely you need to buy a new distributor
Old Apr 19, 2008 | 02:39 PM
Default Re: (Si2See)
there was nothing wrong with my other dizzy..so if it was that it should of fixed the problem
SIDreamer
May 2, 2011 09:51 AM
Unphzd
Dec 13, 2010 11:30 PM
LudeCris
Feb 20, 2006 06:22 PM
YellowR2000x2
Mar 4, 2005 04:29 PM
Krayzielix
Feb 11, 2003 10:10 PM
