can someone give me a quick explanation on why
Old Jan 30, 2003 | 12:23 AM
SlowPoke's Avatar
New User
Default can someone give me a quick explanation on why
the wrx has that really unique sound. It almost sounds like there are two engines or something. I know its a flat 4 but can someone give a little tech info on why the wrx sounds the way it does?
Old Jan 30, 2003 | 12:40 AM
turbohonda's Avatar
Default Re: can someone give me a quick explanation on why (SlowPoke)
The way the engine fires it acts as two 2 piston engines with the same crank. The pistons on the same side of the motor go against each other instead of against the piston on the opposite side. It is kind of hard to explain but if you look at the order each piston fires then it makes it easier to understand.
Old Jan 30, 2003 | 12:46 AM
SlowPoke's Avatar
New User
Default Re: can someone give me a quick explanation on why (turbohonda)
thanks ill look into it but that alreayd helps out thanks
Old Jan 30, 2003 | 01:12 AM
iam7head's Avatar
horzontal oppose..or boxter engine
Old Jan 30, 2003 | 01:24 AM
SlowPoke's Avatar
New User
Default Re: can someone give me a quick explanation on why (iam7head)
ok i understand now how the firing order goes, but how does it make that sound diff from a inline four?
Old Jan 30, 2003 | 02:54 AM
slowman's Avatar
I took way too long
The turbo probably makes it sound unique.
Old Jan 30, 2003 | 02:56 AM
steve_s's Avatar
Default Re: can someone give me a quick explanation on why (slowmanEF)
The turbo does make a different sound, it turns me on. ;-)
TunerD16z6
Aug 11, 2008 01:07 AM
EG_Warped
Dec 14, 2007 02:34 PM
Mr.Hankey
Dec 13, 2006 06:46 AM
SlamMan
Sep 7, 2003 09:19 PM
turboex
Apr 8, 2002 01:37 PM
