Could this damage my cam gears?
Old Mar 23, 2008 | 04:27 PM
TB123's Avatar
Default Could this damage my cam gears?
I am trying to remove my cam gears from the cams. I want to clamp the gears down in a vice so that I can remove the bolt, but I am worried about bending them. Are they strong enough to be clamped down in a vice and not get damaged? Has anyone ever had problems with this?
Old Mar 23, 2008 | 07:42 PM
TB123's Avatar
Default Re: Could this damage my cam gears? (TB123)
How about using an impact wrench? Someone told me that this can hurt the cams. Is this true?
Old Mar 24, 2008 | 04:38 AM
Mikey3000's Avatar
clamp the gear in a vice just don't tighten it too hard, it should be fine. using an impact wouldn't hurt anything unless the cam gear went flying out of the vice and the cam got dinged up. just use a hand wrench.
Old Mar 24, 2008 | 09:13 AM
GhostAccord's Avatar
Default Re: Could this damage my cam gears? (Mikey3000)
If your going to lock her into a vice, make sure you wrap'er a few times with a shop towel/rag first. To make sure that you don't leave any vice imprints or scratch any of the surfaces of the cam while wrenching. I wouldn't bother with an impact for those bolts, there is no need.....ratchet works just fine!
Old Mar 24, 2008 | 12:47 PM
TB123's Avatar
Default Re: Could this damage my cam gears? (GhostAccord)
Well, I tried using a vice and I couldn't get the bolt loose. I had the vice as tight as I could get it, and the gear kept slipping. I think I am going to try an impact wrench now. Do people do this without damaging the cams?
Old Mar 24, 2008 | 01:36 PM
TB123's Avatar
I tried the vice again with a piece of rubber instead of a towel around the gears and I got the bolts loose. Thanks guys.
kpjo4
Jul 11, 2009 06:44 AM
1BADEGDC2
Jul 9, 2008 06:45 PM
RoB316
Aug 29, 2006 07:25 PM
OrangeBoost
13
Apr 25, 2006 06:50 PM
94civicexlsvtec
Jul 30, 2005 02:52 PM
