Help with balljoint removal from the hub
Can anyone tell me how to remove the ball joint from this hub? I cannot see the ring i need to remove in order to wack it out. It doesnt have the little holes so i can pull it appart, even behind where the picture cannot show. Can anyone point me in the right direction?
Re: Help with balljoint removal from the hub (eK9aT10pSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eK9aT10pSi »</TD></TR><TR><TD CLASS="quote">wow,just curious, how did you break the threads?</TD></TR></TABLE>
i cut them off the car because it would spin with the ball joint.
Turns out there was no ring...used a 5 ft bar and a sledge and got the bitch out. The new one slid right in after some hammering. Thanks guys!
Re: Help with balljoint removal from the hub (court)
you have to get the rest of the boot off to get the snapring off then hammer the ball joint out from that side. i have never seen one get stuck so bad a big hammer wouldnt take car of it.
Re: Help with balljoint removal from the hub (schardbody)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schardbody »</TD></TR><TR><TD CLASS="quote">you have to get the rest of the boot off to get the snapring off then hammer the ball joint out from that side. i have never seen one get stuck so bad a big hammer wouldnt take car of it.</TD></TR></TABLE>
sledge hammer had to be employed. Along with a 5 ft pipe that we used as a press. 5 hits and it was out.
Re: Help with balljoint removal from the hub (DeadEnd9009)
Nice job I bitched out and took mine to a machine shop. $20 for both to be pressed out and new ones pressed in
Re: Help with balljoint removal from the hub (spoonracer84eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoonracer84eg »</TD></TR><TR><TD CLASS="quote">Nice job I bitched out and took mine to a machine shop. $20 for both to be pressed out and new ones pressed in </TD></TR></TABLE>
mine was done for free. A shop said it'd be 200 bucks to get everything done, with labor. 65 for the balljoint alone. i paid 27 for it at autozone.....
DIY FTW!!!!!!!!!!!!
DIY FTW!!!!!!!!!!!!
Nocturnal
08-07-2005 08:44 PM
