Lower Ball joint castle nut
Old Jan 19, 2007 | 09:53 AM
M15's Avatar
M15
Default Lower Ball joint castle nut
Okay I am having trouble removing the nut that is holding on the the lower ball joint, I took the cotter pin out and I guess it was tightened before and when I try to turn it the entire ball joint turns also. anyone have any advice?
Old Jan 19, 2007 | 11:59 AM
Perfectionist's Avatar
Default Re: Lower Ball joint castle nut (M15)
Try putting pressure on the joint by placing a jack under the control arm. Otherwise, carefully grab the stud with a vice grips, but you'll probably end up trashing it.
Old Jan 19, 2007 | 12:40 PM
khmboostedeh2's Avatar
Default Re: Lower Ball joint castle nut (Perfectionist)
Jack up the entire hub assembly. It'll put pressure on the ball joint and you should be able to break it free.
Old Jan 19, 2007 | 02:44 PM
02 accord's Avatar
Grind it off.
hot hatch man
Sep 26, 2015 11:13 AM
oranginal
Jul 28, 2010 05:53 AM
kornkid21792
Jan 27, 2010 08:12 PM
chibiko
Jun 6, 2007 08:45 PM
azian21485
May 2, 2005 05:48 PM
