Cali Smog Info?.?.?
Old Jan 4, 2007 | 10:20 PM
Damills's Avatar
Default Cali Smog Info?.?.?
Hey I don't know if I am posting this in the right place but I just recently moved to Northern California and I have heard it is a pain to get your car regeistered here. What is smog and how hard is it to modify cars here legally? Can you turbo a honda a get away with it? Sorry I come fom a state where no emissions anything goes basically I heard this place was a pain in the ***.
Old Jan 4, 2007 | 11:31 PM
91SiZ6's Avatar
Hey, I grew up on Beale. Little shithole that it is. The surrounding area isn't really much better either, hahaha.
Basically, everything has to be CARB exempt or you can contact hazw8st (I'm sure he'll be posting here anyway) for some loopholes.
Old Jan 5, 2007 | 05:03 AM
Damills's Avatar
Default Re: Cali Smog Info?.?.? (Damills)
Yea this base sux I can already tell..... No one else has a post on this any info will help
Old Jan 5, 2007 | 07:20 AM
thesmogman's Avatar
SMOG When we do a smog check we check for three things...
1. Visual Inspection of emissions equipment.
2. Functional testing like EGR. Timing, CEL, and Gas cap.
3. Exhaust sampling.
All original parts have to be on the car, or the replacement parts like a turbo need to be C.A.R.B. approved (California Air Resources Board)
You will have to get a smog check when you bring a car in from out of state if you are going to register it in CA.
Then you will have to get a smog check every two years after that.
You said you were new so I am not going to tell you to use the search button
Also if you want more info go to http://www.dmv.ca.gov
Welcome to California
Old Jan 5, 2007 | 02:41 PM
Damills's Avatar
Default Re: Cali Smog Info?.?.? (thesmogman)
Thanks alot man
Old Jan 5, 2007 | 04:37 PM
Hamstr323's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thesmogman &raquo;</TD></TR><TR><TD CLASS="quote">SMOG When we do a smog check we check for three things...
not completely true
there other ways around it
https://honda-tech.com/zero...age=1
http://www.hondamarketplace.co...age=1
https://honda-tech.com/zerothread?id=1638141
https://honda-tech.com/zerothread?id=1288959
https://honda-tech.com/zerothread?id=1803264
Old Jan 11, 2007 | 06:43 PM
Damills's Avatar
Thanks for the info
Insperation
Southern California
Sep 8, 2008 06:42 PM
ironchef25
Nov 2, 2005 08:39 PM
heavyp
Mar 24, 2003 11:19 PM
Grandma Humper
Jan 9, 2003 01:13 PM
Vanilla4215
Jul 2, 2002 04:33 PM
