burning oil but no leaks
Old 10-06-2018, 07:06 AM
j2lowe's Avatar
Default burning oil but no leaks
my car smelt like burning oil and would kick out blue smoke. my car is a 1.6 vtec 7th gen honda civic sport.i flushed the engine and changed the oil and filter and it appeared to reduce. lmy car has recently had the thermostat changed, expansion bottle, oil pressure switch, egr valve cleaned, head gasket kit full and valve stem seals done. there is still a little smell of burning oil though and no leaks. the oil is using roughly 1 and1/2 litres every 2 tanks of fuel???? help please
Old 10-06-2018, 01:16 PM
thisguyaves's Avatar
Default Re: burning oil but no leaks
Are you losing coolant too? Reduced power? Sounds like head gasket problems.
Old 10-06-2018, 05:18 PM
egsleepercivic's Avatar
rings?
Old 10-06-2018, 11:11 PM
j2lowe's Avatar
the head gasket blew as yes was losing coolant but have done all gaskets valve stem seals expansion bottle etc as stated above... and as to the piston rings i was informed by rac breakdown mechanic that if they had gone there would have been flooded spark plugs which i do not have and a poor idle which again i do not have.as for loss of power. also when i had the head off i checked the piston heads and the cylinders for wear and it appeared none... ????????????
garyguo4
01-29-2019 05:10 PM
that1kidjr
06-15-2011 03:56 PM
vtec-adykt
10
09-16-2005 07:59 AM
BigC-ivic
08-27-2005 07:53 AM
Layziebtnh055
04-28-2004 08:38 AM
Quick Reply: burning oil but no leaks
