Disappearing oil ... WTF?
Old Aug 22, 2005 | 12:51 PM
BigC-ivic's Avatar
Default Disappearing oil ... WTF?
OK, so the other day I as low on oil, I pour two liters into the car and its still low, pour in a 3rd and its fine. (3 litres down... WTF)
There are NO leaks, no puddles anywhere I park.
There is a little whitish smoke on startup, but other than that no noticable smoke.
And there are no deposits on the bumper near the exhaust.
Where the hell is it going if its not leaking and not burning off?
My mechanic said it is a steady but small leak... (is this possible)?
Old Aug 22, 2005 | 02:23 PM
msmotorsports's Avatar
Default Re: Disappearing oil ... WTF? (BigC-ivic)
You may be slightly burning oil through the rings. Also check your coolant to see if there are oil deposits in it. If so, your head gasket is leaking and will need to be replaced.
Old Aug 22, 2005 | 05:20 PM
BigC-ivic's Avatar
Default Re: Disappearing oil ... WTF? (msmotorsports)
Coolant is in great shape. I just changed the head gasket when I put the new head and cams in.
Could I still be burning through the rings?
I did a compression check today, everything was excellent.
Old Aug 24, 2005 | 10:30 AM
BigC-ivic's Avatar
any other ideas?
Old Aug 24, 2005 | 12:09 PM
econorocket's Avatar
PCV system -
Try a catch can
Old Aug 26, 2005 | 12:37 PM
Gqracer's Avatar
your burning oil from the valve stem seal...
Old Aug 26, 2005 | 01:37 PM
BigC-ivic's Avatar
Default Re: Disappearing oil ... WTF? (Gqracer)
so how do I correct this?
do I need new valve seals, or guides?
Old Aug 26, 2005 | 03:39 PM
Gqracer's Avatar
u need valve seals. its a bitch to remove the head and then the valve train
good luck bro
Old Aug 27, 2005 | 07:53 AM
BigC-ivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gqracer &raquo;</TD></TR><TR><TD CLASS="quote">u need valve seals. its a bitch to remove the head and then the valve train
good luck bro</TD></TR></TABLE>
I had the valve seals replaced when I put the new head in (A MONTH AGO)!
I wonder if they are the wrong ones or if they were done improperly
j2lowe
Oct 6, 2018 11:11 PM
that1kidjr
Jun 15, 2011 03:56 PM
90datech
Mar 29, 2007 12:42 PM
vtec-adykt
10
Sep 16, 2005 07:59 AM
Layziebtnh055
Apr 28, 2004 08:38 AM
