Brake bleeding issue
Old Aug 21, 2010 | 06:47 PM
SiHatchTurbo's Avatar
Default Brake bleeding issue
Hello everyone I am hoping someone can help me with this. I have a 95 integra GS-R Sedan no ABS and the issue I have is with my rear my driver side rear caliper not getting fluid to it. I opened up the valve and put a vacuum to it and no fluid comes out. I have open the lines that goes to the master cylinder and blew air through it and it seems that it isn't blocked. I don't think the prop valve I bought that brand new a year ago from the dealer. I just changed out the master cylinder because it was leaking a bit. I am waiting on my pressure bleeder to come in and try to bleed the brakes that way hopefully it works. But I was seeing if anyone has any ideas or has ran into this problem.
Old Aug 22, 2010 | 10:00 PM
Psychoteen101's Avatar
Default Re: Brake bleeding issue
Do you get fluid at any other line? Prop valve could be tripped.
Old Aug 25, 2010 | 07:20 PM
Canuck99's Avatar
Could be, check to see if the right front has pressure or fluid coming out , there on the same brake line circut.
Baby99EX
Suspension & Brakes
11
May 25, 2018 08:08 AM
Chanb0b
Suspension & Brakes
Aug 23, 2017 09:24 AM
red96civicex
Suspension & Brakes
Dec 11, 2009 09:18 PM
rdssk8rcs1
Mar 31, 2008 04:09 AM
