Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Brake issue.
Old Mar 30, 2008 | 09:04 PM
rdssk8rcs1's Avatar
Default Brake issue.
So anyway. I deleted ABS and Im running an aftermarket Prop valve. Tonight I went to bleed my brakes, I started with the rear and everything was fine. Air was coming out, started to get a harder pedal, complete stream of fluid after a couple of cycles. Then i went to the front and it seemed to be working, started to get a steady stream of fluid. But the issue began when I realized the pedal wasn't going down when the fluid was going out. Then I realized that there was no pressure on either front brakes.
Any ideas?
The stream of fluid is consistant with the rears and seams fine, the only issue is the pedal doesn't fall to the floor like it should when the bleeder is open. And there is no pressure on the front brakes.
I thank you in advance to any help or ideas.
Old Mar 30, 2008 | 09:38 PM
jdm-ek-si's Avatar
Default Re: Brake issue. (rdssk8rcs1)
dose this after market prop valve have adjustable brake bias if so i could be on all rear no front
Old Mar 31, 2008 | 04:09 AM
rdssk8rcs1's Avatar
Default Re: Brake issue. (jdm-ek-si)
Well the prop valve im using only controls pressure to the rear. The fronts have lines coming right off the master cylinder.
SPOOLINmatt
Honda Civic (2001 - 2005)
18
Mar 2, 2011 08:09 PM
SiHatchTurbo
Aug 25, 2010 07:20 PM
Chilloutdamn
Nov 4, 2008 03:24 AM
Driven
May 26, 2003 03:29 PM
