bent valve? money shift. help!
Old Dec 24, 2008 | 11:18 AM
Ryanwill86's Avatar
Default bent valve? money shift. help!
soo yea i money shifted from fourth in to third the other night on my b18c swapped ek(on the highway pulling on a vr6). i cough it before it it hit the limiter but now i have a little tick and my exhaust chugs a little sound like a wrx. but the thing is it runs fine and i feel no power loss i just don't what it to arise other problems....plus i hate the sound of a tick. what can and should i do in this situation.
Old Dec 24, 2008 | 11:22 AM
riceburner700's Avatar
Default Re: bent valve? money shift. help!
do a leakdown or compression check
Old Dec 24, 2008 | 11:29 AM
boostedcivicsir's Avatar
Mr. Badwrench
before anything else so now failed upshifts are called money shifts? he hee.
Old Dec 24, 2008 | 12:25 PM
Ryanwill86's Avatar
leakdown test?
Old Dec 24, 2008 | 01:24 PM
arc_55's Avatar
do a leak down or compression test across the cylinders to determine static combustion pressure across the cylinders. This will determine if one has internal issues.
Old Dec 24, 2008 | 02:58 PM
fcm's Avatar
fcm
Old Fart
A tick, tick, tick, check your exhaust manifold/down pipe for a hole/crack, a small leak in manifold/down pipe will "tick". 94
Old Dec 24, 2008 | 03:26 PM
WERA689's Avatar
Originally Posted by Ryanwill86
leakdown test?
A diagnostic test where you pump air into a cylinder and measure how much of the air "leaks" out of the combustion chamber. Up to, say, 10% is acceptable.
This test is more useful than a simple compression test, because it can help you determine exactly where the lost compression is going...ie past rings, intake or exhaust valves. You simply listen at the intake manifold (in valves), exhaust pipe (ex valves), or dipstick (rings) for the sound of air escaping.
For my money, the best diagnostic tool you can use for top end problems.
Old Dec 27, 2008 | 11:44 AM
Ryanwill86's Avatar
when i pop the head if i do whats the sign of the bad valve(what should i look for)....and is it ok to just replace the bent valve and seat(maybe retainer and spring)? the motor only has 40xxx on it. i dono i dont fiddle to much with top ends so i neeed a little in sight here on what route to go.
Old Dec 27, 2008 | 12:06 PM
Ryanwill86's Avatar
ttt
Old Dec 30, 2008 | 11:14 PM
seanbev24's Avatar
don't remove the head yet, the leakdown test that 3 people already suggested will tell you if you have a bad valve, and then you can go from there
Kid-jdm-teggy
Sep 23, 2014 11:11 PM
eac705
Aug 28, 2014 06:50 AM
Goldfingiz
Dec 13, 2002 10:30 PM
Propulsion
Jun 5, 2002 11:48 PM
WOTTEG
Jun 19, 2001 12:53 PM
