bbk throtle body idle problem
Hi, I have a BBK throtle body and noticed it doesn't have that screw in the throtle body like the stock one does to hlep adjust your idle. Is the throtle cable the only way to do it or can I do it some other way? Thanks
i just installed a new bbk 62mm throttle body for my 95 civic ex. When i compared it to the old throttle body (s2000) tb. they look simular. The only difference, is there is a wrench screw where u can adjust the idle, (bottom of where u hok up the throttle cable)). On the bbk it is in the same spot BUT instead of using a wrench or a screw driver, you must use a allan wrench. Just feel under the tb for a while, your find it.
import-tooner
Jul 3, 2013 07:49 AM
Mr. JDM-GSR
Aug 29, 2005 11:33 AM
