edelbrock throttle body issue!
Old 08-29-2005, 10:56 AM
Mr. JDM-GSR's Avatar
Default edelbrock throttle body issue!
well im riding on the highway and when i get off of my exit i notice that i cant give my car any gas. i tried stomping on the gas pedal and nothing works i had to pull over and pop the hood and beat on the cable link for the throttle to open back up.
what can i do to solve this problem because it is really a pain in the butt.
Old 08-29-2005, 11:06 AM
Marauder's Avatar
Default Re: edelbrock throttle body issue! (Mr. JDM-GSR)
Did someone back the idle screw all the way out?
If so, the throttle blade can stick shut. Make sure that the throttle arm is stopping on the idle set screw, instead of the throttle blade closing inside the bore of the throttle body.
Old 08-29-2005, 11:18 AM
Default Re: edelbrock throttle body issue! (Marauder)
on my way to check it out. to make sure i got it straight make sure the idle screw is after plate then being before.
Old 08-29-2005, 11:28 AM
Marauder's Avatar
When the throttle is closed, make sure the arm (where the cable is connected to) stops on the idle set screw. If its backed off at all, it means the throttle blade is closing on the bore of the throttle body. That causes the blade to stick.
Its best to have the arm stop on the idle set screw, and set it so the blade stops just short of fully closed, that way you wont get it stuck.
Old 08-29-2005, 11:33 AM
i just went out there and the screw was a good ways out and i screwit in some and it didnt get stuck it would normally and be a bastard to get loose. i guess after a little run i will be able to make it just right.
THANKS ALOT
TK_209
09-29-2009 06:59 AM
Des9255
10-24-2005 09:58 PM
Jdmbsixteen
17
02-18-2004 07:54 PM
Initial DA6
08-29-2002 03:24 PM
ic108
01-28-2002 10:24 PM
Quick Reply: edelbrock throttle body issue!
