B20 Water Pump Help
Old Mar 6, 2005 | 10:15 PM
JDMeg694's Avatar
Default B20 Water Pump Help
I just got my hands on my B20 Block and wanted to know what water pump to use any b-series water pump will do??? im buying it from inlinefour.com but they dont have a B20 one. i wanted to know if i could use a b16 or a b18 pump thanx in advance
Old Mar 7, 2005 | 03:53 AM
torr's Avatar
Default Re: B20 Water Pump Help (JDMeg694)
b16 and b18 will work, but go with the b18.
b18 and b20 are the same motors with the exception that b18 is 81mm and b20 is 84mm.
Old Mar 7, 2005 | 04:04 AM
NJIN BUILDR's Avatar
Default Re: B20 Water Pump Help (torr)
If you use the B16 or B18c you will need to use a gsr timing belt.If you use the B18a/b or B20 use the ls/cr-v belt.
Glenn
Old Mar 10, 2005 | 08:14 AM
JDMeg694's Avatar
Default Re: B20 Water Pump Help (NJIN BUILDR)
Thanx for the rapid response
si90rex
Nov 27, 2008 07:17 AM
RACEPAK
Aug 17, 2006 10:06 PM
JDM97EK
Feb 11, 2006 09:59 AM
FastGsr95
Dec 23, 2005 10:04 AM
Kataku2K3
Jan 23, 2002 02:51 PM
