b16 oil pump on a b20 question
Old Nov 26, 2008 | 07:13 AM
si90rex's Avatar
Default b16 oil pump on a b20 question
is it wise to put a b16 oil pump on a b20. I have a complete b20 I thought it would be better to put a higher volume oil pump on? I'm building a b20 for my turbo setup i plan on changing it to a b20/vtec in the future.
thanks
Old Nov 26, 2008 | 10:04 AM
tony413's Avatar
what year pre-96 or post-96
either way i think the b16 and b18 pumps are a different size. goto honda and acura and look at the part numbers.
Old Nov 26, 2008 | 10:39 AM
si90rex's Avatar
pre 96.... i believe b16 and itr are the same. well a friend used a b16 on his lsvtec so it should work.
Old Nov 26, 2008 | 12:43 PM
Whatever's Avatar
I believe all the 96+ oil pumps are the same for the B series engines.
Old Nov 26, 2008 | 02:02 PM
tony413's Avatar
that is correct, so i dont think a pre-96 B16 pump will fit on a B18 or B20 block
Old Nov 27, 2008 | 05:55 AM
blackeg's Avatar
x2. im using an obd2 gsr oil pump on my b20 and its good to go
Old Nov 27, 2008 | 07:00 AM
99B16Si's Avatar
the older pumps lack the mounting holes for the crank fluctuation sensor
Old Nov 27, 2008 | 07:17 AM
boostedcivicsir's Avatar
Mr. Badwrench
yup, fwiw, i put an ITR oil pump on an obd1 b16 and one on my obd1 gsr.
g2s
Engine Machining & Assembly
Jun 8, 2016 05:37 AM
vyrus
10
Feb 15, 2012 09:19 AM
eyji-
Dec 14, 2010 09:59 AM
MI4$DC5
Jul 19, 2008 12:16 PM
jdmsijdm
Jun 11, 2004 02:13 PM
