Crank Girdle
Old Jan 20, 2002 | 12:43 PM
Kataku2K3's Avatar
Default Crank Girdle
Will a GSR crank girdle fit on a B20 for CRVTEC? If so what else will I be able to use off my GSR bottom end that will be best for my B20 (oil pump, pickup tube, water pump? oil pan?) Thanks for the help!!!!!!!!!!!!!
[Modified by JDMspecEG6, 11:22 PM 1/23/2002]
Old Jan 20, 2002 | 01:07 PM
Jared's Avatar
Default Re: Crank Girdle (JDMspecEG6)
A gsr girdle will fit a b20 block with modifications, but you'll also need to use the gsr pickup, oil pan, windage tray, etc.. to make everything fit. the gsr oil pump is the same as a b20 so no advantage there. i wouldnt advise using the gsr water pump, unless you'll be turning lots of Rs with that b20, but remember, if you use the b20 water pump, use a b20 timing belt, and vise versa.
good luck,
Jared
Old Jan 20, 2002 | 05:58 PM
Kataku2K3's Avatar
Default Re: Crank Girdle (Jared)
Thanks, what modifications have to done exactly? Is it cuz the has different size mains. Who would you have do this modification?
Old Jan 20, 2002 | 08:37 PM
sgT's Avatar
sgT
its because one of the main caps on the b18c is shorter than the b18a/b/b20
so it has to be milled to fit.
Old Jan 23, 2002 | 02:24 PM
Kataku2K3's Avatar
Default Re: Crank Girdle (sgT)
Can I use the shorter main cap off my B18C or will it not work on the B20. I'm trying to get around milling but if i have to that's what i'm goin to do.
[Modified by JDMspecEG6, 11:25 PM 1/23/2002]
Old Jan 23, 2002 | 02:36 PM
rainforest's Avatar
i thought there was no milling just needed the 3middle main caps and everything below that.baffle,oil pick-up windage tray,oil pan and such.
sgT's Avatar
sgT
why dont you just get the z10 girdle instead
Old Jan 23, 2002 | 02:51 PM
Kataku2K3's Avatar
Does the z10 girdle go right over the B20 mains? What bolts would i use? GSR
sgT's Avatar
sgT
Default Re: Crank Girdle (rainforest)
well, im not sure if the b18c caps fit in a b18a/b/b20, but if they do
you would have to have them align honed so that they match the journals on
the block.
rainforest: if you just use the b18c girdle then you have to mill down the #3 main
cap on the b18a/b/b20 to fit it properly.
MI4$DC5
Jul 19, 2008 12:16 PM
red02s2k
May 8, 2008 08:10 PM
JDMeg694
Mar 10, 2005 08:14 AM
