B20 VTEC TURBO build, need help
Old Feb 2, 2003 | 12:24 PM
RECRU_SOL2000Vti's Avatar
Default B20 VTEC TURBO build, need help
I am now starting the down hill on my turbo project. My focus now is the block, I want to run B20 Turbo w/ a Vtec head. What kind of Building in the Block area should i do, i am running a T3/T4 with this and am looking around 16-20 psi if i can make it in that set up. TH only thing is I have heard that the B20 blocks need some work to hold that. Need advise. I want to go all the way with the block so let me know budget is moderatly high. Anyone in the Houston area let me know.
Old Feb 2, 2003 | 02:19 PM
sslude's Avatar
Default Re: B20 VTEC TURBO build, need help (RECRU_SOL2000Vti)
low compression internales, stronger internals, maybe re-sleeve it. just make sure it's strong
Old Feb 2, 2003 | 02:29 PM
2FASTDC2's Avatar
Default Re: B20 VTEC TURBO build, need help (sslude)
I would resleeve it if you are going to run that amount of boost, B20 have a 7mm sleeve thickness vs 9mm of a b18. Good choice though my buddie made 240whp at 4psi with a b20vtec
Old Feb 2, 2003 | 03:56 PM
NirSpec1's Avatar
Default Re: B20 VTEC TURBO build, need help (2FASTDC2)
ya right 240 at 4 psi.... hahahaha O ya we built that motor.... my bad...
peace
Old Feb 3, 2003 | 09:07 PM
Default Re: B20 VTEC TURBO build, need help (NirSpec1)
Yeah, guys but seriously, anyone have some serious info, i wanna have the car ready by march!
Old Feb 4, 2003 | 08:54 AM
Jeff C's Avatar
Read through this...https://honda-tech.com/zerothread?id=242495.
Old Feb 4, 2003 | 12:55 PM
Default Re: B20 VTEC TURBO build, need help (Jeff C)
Thanks, if you know anyone building, or has built a turbo B20 VTEC, let me know, or if there is anyone with block spec's I can follow please post up!
Old Feb 4, 2003 | 01:12 PM
allmotor92civic's Avatar
http://www.b20vtec.com
Old Feb 4, 2003 | 01:39 PM
Jeff C's Avatar
What specifics do you need?
Old Feb 4, 2003 | 02:56 PM
civic disobedience's Avatar
if you have the $ and want to get a sweet block, check out the DART block. I dont have the link on this machine, but search out Payne technologies, they sell it and have the info. its like $1900.00, but comes sleaved, with steel main caps, and is made of virgin aerospace grade aluminum. I am thinking about using this one myself, I am building it over the next year, maybe as much as 2 years, to build it right!! once!!
Old Feb 4, 2003 | 03:09 PM
AK94GSR's Avatar
Default Re: B20 VTEC TURBO build, need help (allmotor92civic)
Old Feb 4, 2003 | 07:40 PM
Speciffics meaning bottom end build up, and cam choice with a B16A head and a t3/t4 turbo application.
Old Feb 4, 2003 | 07:41 PM
Default Re: B20 VTEC TURBO build, need help (AK94GSR)
Thanks for the site info man, kick-*** site. You have any others like that about b20 VTEC? later
sontdawg
23
Aug 6, 2007 05:56 PM
Scantron
Mar 17, 2006 02:32 PM
allmotorek8
Apr 24, 2005 02:08 PM
othick
Jul 31, 2003 07:35 PM
bzyrice
Mar 19, 2003 08:10 PM
