b20 vtec stumbles at idle?????
Old Jun 22, 2013 | 12:56 PM
B20vtec veteran's Avatar
Icon2 b20 vtec stumbles at idle?????
whats up guys... im having a issue with my 98 civic. its b20vtec swapped converted to obd1. The issue i am having is the car is stumbling at idle futuating too 1200 rpms to 500 and feels like it wants to stall, everytime it stumbles the a/f gauge jjumps too.... its also running lean according to the A/F gauge. its a lil eratic when warming up...... i have a cel for the 02 sensor heater. i measured the tps votage at the ecu and sensor and it checked out. i also cleaned the iac and it did nothing.... does anyone have an idea what could be causing this problem???? is there any ohms specs for the factory tps????
Old Jun 22, 2013 | 08:43 PM
hybridmiklo's Avatar
Default Re: b20 vtec stumbles at idle?????
what model civic is this? and which injectors did you use? And also you should always start with the cel. if its throwing a code for o2 sensor heater you need to check that the heater circuit has power to the o2 sensor. then check resistance across the heater circuit of the o2 sensor to verify its bad.
Old Jun 23, 2013 | 09:38 AM
It's a dx model and as for the o2 I'm
Going to check It today..the cel light was on before this issue started though..
Old Jun 23, 2013 | 09:39 AM
Oh and stock injectors
Old Jun 23, 2013 | 09:55 AM
y7 injectors or b20 injectors? the y7 injectors are smaller than the b20s and that will give you a weird idle and the car will run like junk. I ran into a similar issue when I swapped a 96 civic dx. They are rated at 180cc.
Old Jun 23, 2013 | 02:33 PM
There b series injectors and the car has been swapped for a year now I just started having this issue, I also noticed today when I was driving at a steady rpm it miss fired a couple times the problem is intermittent... I'm stumped because i only have a light on for the o2 and I never came across any cars running like **** with a bad 02
Old Jun 23, 2013 | 02:35 PM
The power feels like it still there at wot the a/f goes up but at normal driving or idle it says its running lean
Old Jun 23, 2013 | 03:24 PM
I have. When you are wot the ecu doesn't look at the 02 sensor. The o2 sensor is used at idle and at cruising to determine if the vehicle needs more fuel or less. A bad o2 sensor will send false readings and give you hesitation while cruising and at idle and give you a misfire. Start with the obvious
Old Jun 23, 2013 | 04:26 PM
Ok I'll get a new hopefully it fixes it .. the cel was on before for this and I didn't have this problem .... Would there e anything else causing this ??? I just started the car and its reading lean but every time it misses the a/f goes up to stoich!!
Old Jun 23, 2013 | 04:29 PM
The car also stalled on me at a red light
HondaPartsHero's Avatar
Technical Hero
What kind of A/F meter are you using? If its the autometer type throw it away because its only good for a light show.
Old Jun 24, 2013 | 01:58 AM
JDMAF's Avatar
What ECU are you running???
Old Jun 24, 2013 | 01:24 PM
Lol that is the one I have but that Dosent solve my issue I'm running a p28.... Someone looked at my car yesterday and said my tps is bad.....i unplugged it and it didn't change anything but i did test the tps voltage and it checked out
Old Jun 24, 2013 | 01:26 PM
I bought a map sensor and a new tps but haven't put them on yet.
Old Jun 25, 2013 | 08:46 AM
**update** I changed the tps sensor and the car stopped stumbling and is way more responsive to the throttle.... But it's barely reading lean still I wasn't having this problem before even though I had a cel for the 02 can anyone help me out ??
candymanjl
Oct 6, 2006 03:41 AM
Jayboy
13
Jun 19, 2005 12:29 AM
GOTNOS
Nov 22, 2004 03:19 PM
kHoA DoGG
26
Dec 28, 2002 09:14 AM
kHoA DoGG
Nov 20, 2002 05:25 PM
