B18B1 LS Engine Help
Old Jul 22, 2013 | 12:59 PM
Memphis5031's Avatar
Default B18B1 LS Engine Help
Hey guys got a question for ya'll and need an answer from the experts.
My 95 Civic EX has a fully swapped B18B1 with a GSR Hydro tranny. The previous owner had the LS VTech head on it and to my knowledge probably blew it up and put the non v-tec head on which is running my car now. It is also been set up in his previous days for turbo. But I don't exactly know what the previous owner has actually done to the motor, but just as a mild guess I will say its all stock, except for my headers, JDM intake, fuel rail and throttle body that I put on myself replacing the original USDM parts.
Now to get to the question, I have purchased some crane cams, stage 2, and was wondering if my drive train is stock could I run those cams in my car without upgrading my springs, retainers, and valves. A really good Honda technician told me I could as long as I don't hit seven grand on my rpm range, is this true? The only main concern that I have is if I do this will I throw something or snap a spring?
Old Jul 23, 2013 | 05:39 PM
fcm's Avatar
fcm
Old Fart
Default Re: B18B1 LS Engine Help
My question is, if you are not going to upgrade the springs, what is the point of installing the cams??? 94
Old Jul 23, 2013 | 05:44 PM
YellowBacteria1's Avatar
so you bought the cams before you even knew if you could use them. genius.
I've seen B18B's revved past 7k numerous times. is it healthy? no. is it impossible? no. is it going to blow the engine? no.
I wish I had a JDM intake.
install the cams and see what happens, maybe you drop a valve, bend a valve, maybe you put a hole in a piston.
or just maybe... just maybe, when you hit 88mph you blast into the future.
Old Jul 24, 2013 | 03:18 AM
Well the only reason I bought the cans is because they were being sold for a stupid low price, then I called crane came and they are what they and the guy who sold them to me said they are. Yes In defiantly gonna upgrade my drive train, ie. dual springs, retainers, high compression valves, etc, but wanted to know if they would go in now cause the seller told me they would, so instead of just listening I wanted expert advice first. Now, so you guys don't think In an idiot, i will upgrade my engine first. But worst comes to worse I can always sell them and almost not loose out at all. Anyone need cams?
Old Jul 24, 2013 | 05:11 AM
kyden's Avatar
i don't see the point of those cams without raising compression first.
Old Jul 25, 2013 | 07:43 PM
schneedrache's Avatar
[QUOTE=or just maybe... just maybe, when you hit 88mph you blast into the future.[/QUOTE]
Lmao. Bout pooped myself.
Old Sep 24, 2013 | 05:27 PM
the580smurf27's Avatar
whats up people i have a b18a1 that im rebuilding and i need the torque sequence and the specs but i live in the country and my net sucks is there anyone that has the info and able to email it to me ?? also the head is a b16 head im ganna need the torque specs for it alsothe guy that owned it before me said it had an idle problem i guess any info on that would be much needed also
Old Sep 25, 2013 | 05:25 PM
Am i the only one here
Old Sep 28, 2013 | 06:12 AM
grjr's Avatar
start your own thread
Jm98ek
Apr 14, 2019 08:11 PM
enemy no1
Mar 29, 2011 02:47 PM
TwitchDa9
30
Feb 2, 2011 04:35 AM
dan's integra
Feb 11, 2007 03:02 PM
Rah Rah
Jun 28, 2002 02:24 AM
