b18a1 rod bearings clearances issue...
Old 02-17-2010, 07:55 PM
viera's Avatar
Default b18a1 rod bearings clearances issue...
just plastigauge them and got
.001
.0015
.0015
.0015
the first one seems to be too tight and after i torque them i cant spin the crank. crank was polish & balance, i swap bearings on 1with 4 and get the same results. do guys think rod 1 could be bad?? its used with low miles.
Old 02-17-2010, 09:19 PM
PyroProblem's Avatar
Default Re: b18a1 rod bearings clearances issue...
Does the tight one follow the bearing? or stay with the rod?
Were these recently machined?
Old 02-18-2010, 04:35 AM
viera's Avatar
The rods were not machined. it does get tight after I torque down that rod once I losen it by a lil I can spin the crank with no problem
Old 02-18-2010, 04:41 AM
viera's Avatar
Did u get ur rod bolts issue resolved?
Old 02-18-2010, 06:15 AM
t3am spotlit3's Avatar
i might be wrong but honda only allow .0013-.0025
so your frist one might be bad
Old 02-18-2010, 06:50 AM
viera's Avatar
i just dont understand how #1 journal is bigger now, if anything should of be smaller. i might just look for an other crank
Old 02-18-2010, 12:13 PM
clutchrsx's Avatar
what kind of bearings are u using?
Old 02-18-2010, 12:18 PM
viera's Avatar
std acl
Old 02-18-2010, 02:56 PM
viera's Avatar
just took my crank out and rod #1 going to the machine shop tomorrow. i think my problem is with the rod. will see...
Old 02-18-2010, 06:38 PM
Bring all the rods and the rod bearings youll be using too. Id let them measure everything again just to be safe. Theyll be able to correct anything that needs it before you discover it on your own...
MAKE SURE THEY DONT OVERTORQUE THE ROD BOLTS like my machine shop did. I will be having to re-purchase rod bolts due to their mistake that they wont man up to...
Good luck!
Old 02-19-2010, 09:15 AM
viera's Avatar
just got back from the shop and i got screw from buying use **** one rod is not the same as the others. i call eagle and one rod is going to coast me 100.00 lucky me.......
Old 02-19-2010, 11:46 AM
viera's Avatar
well guys i feel like an ***...lol i had the caps mixed up torque everything down and now the crank spins nice like it should.
fyi rods and caps are stamp with matching #'s
Old 02-19-2010, 12:09 PM
K7-1Ktrevor's Avatar
lol. glad you figured it out. just a rookie mistake
95hondasedan
11-17-2014 07:45 AM
jlfrnce
09-02-2009 01:30 PM
eg4life1202
11
01-14-2007 09:17 AM
hatchedzex
10-04-2004 11:40 AM
v4lu3s
07-26-2004 11:25 AM
Quick Reply: b18a1 rod bearings clearances issue...
