b18a1 rod bearings clearances issue...
just plastigauge them and got
.001 .0015 .0015 .0015 the first one seems to be too tight and after i torque them i cant spin the crank. crank was polish & balance, i swap bearings on 1with 4 and get the same results. do guys think rod 1 could be bad?? its used with low miles. |
Re: b18a1 rod bearings clearances issue...
Does the tight one follow the bearing? or stay with the rod?
Were these recently machined? |
The rods were not machined. it does get tight after I torque down that rod once I losen it by a lil I can spin the crank with no problem
Did u get ur rod bolts issue resolved?
i might be wrong but honda only allow .0013-.0025
so your frist one might be bad |
i just dont understand how #1 journal is bigger now, if anything should of be smaller. i might just look for an other crank
what kind of bearings are u using?
std acl
just took my crank out and rod #1 going to the machine shop tomorrow. i think my problem is with the rod. will see...
Bring all the rods and the rod bearings youll be using too. Id let them measure everything again just to be safe. Theyll be able to correct anything that needs it before you discover it on your own...
MAKE SURE THEY DONT OVERTORQUE THE ROD BOLTS like my machine shop did. I will be having to re-purchase rod bolts due to their mistake that they wont man up to... Good luck! |
just got back from the shop and i got screw from buying use shit :mad: one rod is not the same as the others. i call eagle and one rod is going to coast me 100.00 lucky me.......
well guys i feel like an ass...lol i had the caps mixed up torque everything down and now the crank spins nice like it should.
fyi rods and caps are stamp with matching #'s |
lol. glad you figured it out. just a rookie mistake :)
