b16a1 vs b16a2
Old Dec 5, 2003 | 03:10 PM
h1coupe's Avatar
Default b16a1 vs b16a2
i am rebuilding a hydrolocked b16a2(obd-1 grey plug)
and i am looking for a new block!
my question is is there a difference in the blocks of the b16a1 and the b16a2(i am talking about just the bare blocks with nothing in them)
Old Dec 5, 2003 | 03:23 PM
976's Avatar
976
New User
Default Re: b16a1 vs b16a2 (h1coupe)
JDM or USDM?
Old Dec 5, 2003 | 03:24 PM
JDMHN8's Avatar
Well, for one, there is no such engine as the B16A1. I guess you are refering to the OBD-0 JDM B16A. It runs 10.2:1 CR and with its PR3 pistons. 160HP
If you're talking about a real B16A2, then it's identical to the OBD-0 B16A (same pistons and output) except for some manufacturing improvements, cams and OBD-II. It was only found in the 1999-00 Civic Si. 160HP
The OBD-I JDM B16A came with P30 piston, perhaps some better manufacturing processes and made 170HP. It is not a B16A2.
Newer blocks tend to be higher quality.
Old Dec 5, 2003 | 06:26 PM
pills_PMD's Avatar
Default Re: b16a1 vs b16a2 (JDMDA9)
the casting is the same.
i know that the obd1 version has a knock sensor, but i'm not sure if the obd-0 one does...
anyone>?
Old Dec 5, 2003 | 07:44 PM
photec3's Avatar
Default Re: b16a1 vs b16a2 (pills_PMD)
obd 0 does not
Old Dec 6, 2003 | 04:17 AM
h1coupe's Avatar
Default Re: b16a1 vs b16a2 (photec3)
there is a b16a1 here in europe it came in the civic/crx 90-91 it has 150hp!
it is obd-0 i think!
mine is a b16a2 obd-1 from a 92-95! i also have a head off an 96-98si (dont know if it´s obd-1or 2)
but photec3 is there a hole for the knock sensor in the obd-0 block or is it from another cast?
so the only thing i need to look for when i get block is that there is a hole for the knock sensor?
thanks for your help guys
Old Dec 6, 2003 | 04:20 AM
h1coupe's Avatar
also i have the pr3 pistons!
Coldth1
63
May 18, 2016 11:59 AM
flowmaniacscrew
Jul 29, 2009 08:49 PM
MugenHonda
Dec 3, 2005 06:46 AM
Jesterian
Aug 31, 2005 04:02 AM
poetter
12
Feb 24, 2005 10:46 AM
