B16A1 head removal, need a lil help
Old Dec 29, 2003 | 01:07 AM
Sleepin Crx's Avatar
Default B16A1 head removal, need a lil help
well i blew my head on my motor, now im gonna replace the head but first i need to take her off.
I was gonna do it yesterday but i didnt have time so im doing it today. Anyways i took off the valve cover, IM bracket inthe back and some wires then i ran out of time. Anywhoo i just wanna take of the head right off, dont wanan remove anything because im just swapping heads, now what do i need 2 take off, do i need 2 take off the cams? how many head bolts are there?
from what i have seen im under the impression that the cams come off and the headbolts are around there somewhere, anyways if somebody would be kind 2 gimme some info on this that'll be great, ty
Old Dec 29, 2003 | 02:07 AM
Default Re: B16A1 head removal, need a lil help (Sleepin Crx)
any1 please?
Old Dec 29, 2003 | 02:23 AM
Xsi's Avatar
Xsi
Dude, it really sounds like you have no idea but if you really want to have a go at it, fair enough, thats how I learned everything I know.
Download the VTEC B16A supplement from here and it will give you a good guide.
http://a.domaindlx.com/jimbob/B16A%20Manual.pdf
Right click: save target as
Old Dec 29, 2003 | 04:39 AM
Ruby Civic's Avatar
Default Re: (Xsi)
proly blew the head GASKET...you will need to check the mating surfaces of the head and the block to make sure no damage also ...that they are level with a true straight edge....as he said gotta remove the cams, then the head bolts or studs, etc.
Old Dec 29, 2003 | 06:31 AM
usdm420's Avatar
816d16 owes me money!
Community Builder
Community Influencer
Active Streak: 30 Days
Default Re: (Ruby Civic)
yes you have to remove both cams, so yer gonna have to remove the distributor first.
Old Jan 3, 2004 | 09:45 AM
Default Re: (usdm420)
well i removed the cams and all hoses and everything, im gonna take a pic in a lil bit cause i gotta go out but after the cams come out, what do i do now? i dont see anything else left 2 do, can some1 tell me like step by step after the cams are removed?
yeah my timing belt snapped, and yea my headgasket blew (too much juice) i need 2 check the damage ont he valves since its 99.99% that one of the pistons kissed the valves
i really need some1's help here on what to do next, i'll post pics later
ty
Old Jan 3, 2004 | 01:47 PM
onePOINTsix's Avatar
Default Re: (Sleepin Crx)
if the timing belt snaped your fucked, time for a new engine because you just buried a valve into one of youe pistons
Old Jan 3, 2004 | 06:24 PM
4crx4me's Avatar
Default Re: (Sideout)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sideout &raquo;</TD></TR><TR><TD CLASS="quote">if the timing belt snaped your fucked, time for a new engine because you just buried a valve into one of youe pistons</TD></TR></TABLE>
Not necessarily. That's a worst case scenario.
I can't remember if B series VTEC's are even interference engines or not.
Firestarter
Nov 5, 2005 01:30 PM
Mike banX
Oct 20, 2004 07:47 AM
JDMvtecDRAGSTA
Apr 18, 2002 12:07 PM
B_CRUZ!
Jan 10, 2002 10:49 PM
