b16a1 ENGINE KNOCK! HELP!
Old Feb 22, 2005 | 03:38 PM
The Setup's Avatar
Default b16a1 ENGINE KNOCK! HELP! (sound clip inside)
Car: 1991 Civic DX
Engine: B16A/ Y1 Tranny
ECU: unsure
Distributor: recently (replaced by Honda)
Plugs: less than 10,000k
Alternator: New (replaced by Honda)
T-belt: brand new (replaced by Honda)
Rad: brand new (replaced by Honda)
Oil: replaced less than 1000km's ago
I have had bad LMA's for about 3 months, and just have not had the cash to replace them (sounds like a little tick tick tick tick tick). But I was supposed to do it this week, I finally got some money.
Now, my engine is making this knocking sound all the time (cold or warmed up). It sounds like someone is knocking with their knuckle on the spark plug cover! I could probably take a sound clip, and post it if needed. Sounds like its coming from the top of the motor, and the 'knock' goes with the RPM of the motor as well, and is VERY noticible.
But I really need help... I don't want my little car to die! What could be wrong? I'm no mechanic at all, so I want to have some knowledge before I take it somewhere.
*******************edit***********sound clip added
SOUND CLIP
http://users.electrocity.ca/dru/cold.wav
http://users.electrocity.ca/dru/warm.wav
Modified by The Setup at 1:19 AM 2/23/2005
Modified by The Setup at 1:20 AM 2/23/2005
Old Feb 22, 2005 | 04:00 PM
mmuller's Avatar
Mad Scientist
Default Re: b16a1 ENGINE KNOCK! HELP! (The Setup)
we want a sound clip
Old Feb 22, 2005 | 04:19 PM
The Setup's Avatar
Default Re: b16a1 ENGINE KNOCK! HELP! (mmuller)
SOUND CLIP
Old Feb 22, 2005 | 06:06 PM
The Setup's Avatar
LOL! It's staying parked till i get an answer! I think thats the safest thing to do.
Old Feb 22, 2005 | 06:32 PM
mmuller's Avatar
Mad Scientist
not detonation.
doesnt sound like a knock...but could be just the recorder
sounds stupid, but check if you have a leak in the header flange.
did it start doing it right away or..
Old Feb 22, 2005 | 06:40 PM
sickerhatch's Avatar
that sounds like a header leak to me check the two round gaskets
Old Feb 22, 2005 | 06:47 PM
The Setup's Avatar
Default Re: b16a1 ENGINE KNOCK! HELP! (sickerhatch)
Theres nothing leaking.
It lierally sounds like its comign from the top of the motor... how could a header leak do that?
Old Feb 22, 2005 | 08:20 PM
fatts's Avatar
Could be your valves! What kind of oil are you running?
Old Feb 22, 2005 | 10:03 PM
thatbluecrx's Avatar
Default Re: b16a1 ENGINE KNOCK! HELP! (fatts)
this mite sound dumb too but check ur spark plugs, see if one is loose
Old Feb 22, 2005 | 10:40 PM
B16EKrevdupto10krpm's Avatar
I had the same problem and all it was, the spark plugs were loose. Sounds lame but true.
Old Feb 22, 2005 | 11:07 PM
poison's Avatar
Default Re: b16a1 ENGINE KNOCK! HELP! (wicklewon1)
Check and make sure the spark plugs are torqued, check the clearance for your valves...eg valve lashing.
Get a feeler gauge and check the clearances between the cam lobe and the rocker arms. .006 for the exhaust, and .007 for the intake.
Old Feb 23, 2005 | 12:36 AM
ntgr8td's Avatar
Default Re: b16a1 ENGINE KNOCK! HELP! (poison)
i must agree, that sounds like a ignition noise to me. sounds like a wire is loose and grounding to the head (spark plug hole tube) or compression like a loose spark plug.
pull your plug wires, check for soot usually white, that is tell tale evidence of arching.
good luck
Old Mar 22, 2005 | 06:24 PM
The Setup's Avatar
Default Re: b16a1 ENGINE KNOCK! HELP! (thatbluecrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thatbluecrx &raquo;</TD></TR><TR><TD CLASS="quote">this mite sound dumb too but check ur spark plugs, see if one is loose </TD></TR></TABLE>
LOL! I checked right away.. guess what it was. Spark plug was loose and was hitting the spark club cover.
(btw... sorry for responding like a month later)
Old Mar 23, 2005 | 12:00 AM
Take out spark wires and plugs blow off and return tightly problem fixed!!!!!
B18beone
Nov 23, 2017 02:06 AM
WilliamP
14
Oct 12, 2015 05:15 PM
nazafi
Jul 28, 2015 03:37 PM
Delano5050
Jan 30, 2007 08:02 PM
