b16a top dead center sensor?
Old May 2, 2011 | 11:18 AM
B16a_delsol94's Avatar
Icon2 b16a top dead center sensor?
hey everyone i have obd1 b16a swapped into my 94 delsol and its throwing code 8 which is top dead center sensor and ive been searching and searching but i cant find any information on this or where it is located. any info would be much appreciated cause my car does not run right now. thanks
Old May 2, 2011 | 12:21 PM
saywhat's Avatar
Default Re: b16a top dead center sensor?
Sometimes when you mix up the plug wires it will throw this code. Verify your timing and make sure you have the correct wires going to the correct plugs. The TDC sensor is in the distributor.
Old May 3, 2011 | 09:14 AM
slowcivic2k's Avatar
In most cases, either the TDC sensor is open (unlikely, but can happen), or the wires are flipped the wrong way. Fix that first.
Mixing the plug wires will not set that code...
blue_hatch
Feb 16, 2011 01:49 PM
dump3deg6
15
Jan 18, 2009 12:05 PM
Fmaxpa
Oct 30, 2007 10:26 AM
Mastuh4
Nov 3, 2004 09:49 AM
phatdoughnut
Aug 11, 2003 10:18 PM
