b16a starting problems
Old Jul 28, 2004 | 10:46 AM
lu2hot's Avatar
Default integra b16a starting problems with distributor
recently my old distributor bearing went bad so i purchase an aftermarket one from canada. however, the teeth on the new one is smaller than the original. i accidently put the wrong side of teeth into the camshaft and try to crank it. it didn't start so i pull the distributor back off and realize that it was in the wrong fitting. i twist the teeth 180 degree around and put it back in correctly, however, this time car still wouldn't start but there is a bit of back fire. i check the fuel and it was fine. i also send the distributor back to the manufacture and they told me it was fine as well. i check the all the connection and seems to be in place. can anyone help me and give me some suggestion? my car was running fine before the old distributor went bad. did i mess up the engine by putting the distributor teeth on the wrong side to the camshaft? the cam is still turning went i crank. could it also be the timing as well? could the bad bearing from the old distributor mess up the internals? HELP ME!!!!! i'm receiving my new distributor back from the manufacture tomorrow and i want to know what to do before intalling it again.
Modified by lu2hot at 3:22 AM 7/30/2004
everlight44
Mar 12, 2009 07:57 PM
irishgod247
Mar 13, 2007 10:35 AM
trooper0641
Jul 25, 2005 12:03 PM
lu2hot
Jul 30, 2004 05:45 PM
