throwing a CEL and i cant fix...help!?!
Old Jul 27, 2004 | 02:13 PM
IEATLINT's Avatar
Default throwing a CEL and i cant fix...help!?!
my jdm b16 in my 92 civic vx hatch is throwing CEL #9 which all my research tells me that it is the Cylinder TDC sensor which is in the distributor. i am now on my third distributor w/ the same code and help anyone can offer??? thank you
Old Jul 27, 2004 | 03:24 PM
murtnabila's Avatar
Default Re: throwing a CEL and i cant fix...help!?! (IEATLINT)
have you reset it? (pull out battery wait for a few hours and put back on?)
Old Jul 28, 2004 | 04:56 AM
JimBlake's Avatar
The ECU can't tell the difference between a bad sensor vs. flaky wiring connections. Check the circuit - don't just assume it's the sensor itself.
Old Jul 28, 2004 | 11:31 AM
IEATLINT's Avatar
Default Re: throwing a CEL and i cant fix...help!?! (JimBlake)
yes i have reset the ecu...before each new distributor. i'll check the circuit tonight and see if its bad.
SkIp_Civic_Ek6
Nov 27, 2019 10:08 AM
egvtec
Apr 17, 2010 04:58 PM
kumar*
Aug 28, 2007 09:25 AM
athoughts
12
Jul 3, 2005 10:16 AM
IEATLINT
Jul 27, 2004 02:13 PM
