B16a,B18b, or D16
Old Nov 28, 2002 | 08:08 PM
V8killa1.8's Avatar
Default B16a,B18b, or D16
O.k., I want the fastest and cheapest setup, to put in a crx. What is my best choice. LS turbo with a stock bottom end. B16a turbo with a stock bottom end, or put a sohc vtec head on a crx si motor, and build the bottom end and boost more.
Old Nov 28, 2002 | 08:17 PM
Urban Business
Guest
Posts: n/a
Default Re: B16a,B18b, or D16 (V8killa1.8)
fastest and cheapest depends on how mechanically incluned you are and how well you can tune
b16a turbo can beat a b18b turbo
b18b turbo can beat a b16a turbo
tuned d16 can beat crazy **** it shouldnt be able to beat
Old Nov 28, 2002 | 09:04 PM
Eee Pee's Avatar
Default Re: B16a,B18b, or D16 (TorteX)
Hit it!
Old Nov 29, 2002 | 08:45 AM
InfamousRS's Avatar
Default Re: B16a,B18b, or D16 (E Prep)
D16!!!!! I told you!!!!!!
D16
supra pistons
b16 rods
Block gaurd
SOHC Vtec head
Rebuilt Saab 900 turbo
Cheep used manifold, or custom manfiold(by InfamousRS)
Sterion intercooler
Custom pipping (by InfamousRS)
1st gen DSM BOV
Zips SMC
DSM 450 injectors
10 psi for now (upgrade the fuel system to hondata and you can boost 1 bar!!!)
Lets do it Landon, you don't need no 2 cams!!!!
Old Nov 29, 2002 | 09:23 AM
337 GTI 1.8t's Avatar
built, tuned and boostd D16 will be the easiest to setup and most fun on the street; i say most fun on te street cuz you will be so poor from building and boosting the dohc's that you will not be able to afford gas, in turn, you wont be able to drive, and that is no fun...
Old Nov 29, 2002 | 09:47 AM
mrlegoman's Avatar
Default Re: B16a,B18b, or D16 (InfamousRS)
D16
supra pistons
b16 rods
Block gaurd
SOHC Vtec head
Sterion intercooler
1st gen DSM BOV
Zips SMC
DSM 450 injectors
Sounds like fun. Do you have any links to other posts or sites with more info?
Old Nov 29, 2002 | 09:49 AM
DevinW's Avatar
Just keep building the D16
Old Nov 29, 2002 | 10:40 AM
ExospeedAMcrx's Avatar
Default Re: B16a,B18b, or D16 (mrlegoman)
if you go the D16 route, I'd spend the good money on a good manifold and turbo setup. I wouldnt do the Junkyard way on those parts, those are what will make the diff from Fast to FASTER. We had TO4B on a drag manifold and Starion intercooler setup back in 1996 on a CRX Si. at 9lbs it hit a 13.00 on a stock motor with 310injectors.
Old Nov 29, 2002 | 12:36 PM
V8killa1.8's Avatar
Yes Ryan, I agree with you, I just wanted to see what other people thought. Do you think I could do the whole car for under $5000. It would have to be one of the cheapest hondas ever built that was actually fast. I think it would surprise alot of people. How much would a nice manifold, turbo, and hondata cost?
Old Dec 3, 2002 | 08:30 PM
StorminMatt's Avatar
Unless you upgrade to a 1992+ ECU, forget the Hondata. With the sole exception of the PR3/PW0 B16A ECUs, Hondata does not do pre-1992 ECUs.
Old Dec 3, 2002 | 09:20 PM
Kataku2K3's Avatar
Default Re: B16a,B18b, or D16 (StorminMatt)
My friend's B16A CRX ran 13.52@101 with MT 20x6x14 slicks... That was a totally stock motor... He only had an intake and 2.5" exhaust and the car weighed 2060 full interior with him in it.... Not bad... If you are not looking for a full out motor then why not just boost a B16 on like 6lbs... My friend's internally stock B16 in his EK on 7lbs. ran 12.8@106... The CRX should be a lot faster.....
Old Dec 3, 2002 | 10:26 PM
InfamousRS's Avatar
Has already been considered.
cityofcaterpillars
May 26, 2016 04:38 AM
savestheday
Feb 26, 2011 07:24 AM
Timmayeg
Feb 15, 2003 08:39 AM
RaceBred
Jul 24, 2001 10:06 AM
