B16 Start and idle issues
Old Mar 31, 2003 | 02:24 PM
GreensleeperB16's Avatar
Default B16 Start and idle issues
Running a jdm b16a with obd1 delsol dohc ECU intake mani and sensors in a 94cx HB. Car idles terribly.... It acts as if the the coolant has air in the line causing the lower TB sensor to read funny... Youguys know the typical 800-1500 rpm back and forth surging. Everything works (vtec) etc.... but car will start to run hot... ACK...
Also the car now is having trouble cold starting. I have to give it gas or it dies. If i hold it at like 2000rpm for a few seconds it will start to go through cold start cycle. I fi dotn the car misses and idles around 250rpm and dies...
Please help guys
Bryan
Old Mar 31, 2003 | 07:27 PM
Default Re: B16 Start and idle issues (GreensleeperB16)
Anyone have an idea? please... this has been really frustrating...
Bryan
Old Mar 31, 2003 | 11:58 PM
riceboy's Avatar
have you checked that coolant screw on the bottom of the throttle body?
are there and CELs?
Old Apr 1, 2003 | 08:34 AM
Default Re: B16 Start and idle issues (riceboy)
I have checked the coolant screw and it has not backed out.... i also bleed the coolant several times.... No cels either
Bryan
Old Apr 1, 2003 | 05:00 PM
Xsi's Avatar
Xsi
I have a similar problem, have you checked the lower radiator hose? does it feel cold even at operating temp? mine does.
Old Apr 2, 2003 | 07:34 AM
Default Re: B16 Start and idle issues (Xsi)
Xsi,
Tell me what you car is doing i havent been able to check the lower radiator hose yet. Does yours also have trouble starting?
Old Apr 2, 2003 | 07:40 AM
sander's Avatar
2.7(p/t)
if your lower radiator hose is still cold at full operating temp then your thermostat is stuck shut.
eg6noise
Aug 19, 2017 12:01 PM
JJexpress
May 19, 2009 03:16 PM
pheardone
Jan 3, 2009 01:46 PM
busyychild
May 11, 2007 05:13 AM
hatch4raceb16
Jul 6, 2004 06:33 AM
