B16 Crank Mains
Old Jun 18, 2006 | 06:08 PM
URNVS's Avatar
Default B16 Crank Mains
Does anyone make an aftermarket set? Is there any point to them? Whats the max HP/RPM achieveable on a stock set? Does ARP make a set of studs for the bottom end and if so are they worth it?
Modified by URNVS at 11:33 PM 6/18/2006
Old Jun 18, 2006 | 08:45 PM
FIGARILA's Avatar
Default Re: B16 Crank Mains (URNVS)
If you search for user Earl he has some good info, on ARP studs. From what i read arp studs require a higher torque rating, which tends to warp the alum. side of the mains. Don't worry as long as you are able to measure the crank bores before and after you might be able to get away with the arp studs. Golden eagle offers main studs that use the same oem torque ratings. In the end there really not needed unless your making crazy power.
Old Jun 18, 2006 | 09:32 PM
URNVS's Avatar
Default Re: B16 Crank Mains (Heron of Alexandria)
Crazy = 400,600,800HP?
MalcolmV8
Sep 24, 2012 07:00 AM
Cap'N Chronic
Oct 16, 2011 06:47 AM
lsturbo*
Sep 13, 2007 02:30 PM
pentaq
May 31, 2006 10:10 AM
b18cx
Mar 4, 2004 12:48 PM
