assembly questions need answered
Old Apr 22, 2011 | 10:14 AM
sh!ft's Avatar
Who the fack changed my title?!
Default assembly questions need answered
Ok, so, let me get this straight before I do anything stupid. as well as a little background info on my motor.
i am running a crank(gsr) which has been cut .20 over. both rod and mains. i have .20/.20 bearings and thrusts washers. are these the equation(s) i am supposed to measure for/come up with? listed below:
-widest point on main caps tightened down MINUS the width of the crank mains= my gap clearance for bearings which is my acceptable indication marking for when i apply the plasti gauge?
-widest point on rods MINUS the width of the journal on the crank= gap clearance for bearings which is what i need to check for on plasti gauge when measurement/tightening is taken?
im still a tad bit confused.
Old Apr 22, 2011 | 01:23 PM
mouab18c1's Avatar
Default Re: assembly questions need answered
http://youtu.be/mpy_By5aIxM
http://youtu.be/MtTXA9_a8sI
http://youtu.be/JE7U5l_MoP8
Old Apr 23, 2011 | 01:49 PM
EG1834's Avatar
You want to measure 90 degrees to the parting lines of the bearing, or basically 6 and 12 o'clock. This is where the clearance is the tightest.
M2S~Jaime
Mar 27, 2008 10:32 AM
bluedlude
39
Jan 27, 2008 12:42 PM
turbosi03
Aug 6, 2004 10:35 AM
B18EG6
Aug 3, 2003 01:19 PM
Eric Schieb
Nov 30, 2001 07:04 PM
