ACL main bearings
Old Mar 27, 2008 | 09:32 AM
M2S~Jaime's Avatar
Default ACL main bearings
After the crank was properly torqued, spun to find that the ACL mains on were a little worn in the middles. Like the coat was already worn off. Is this normal for ACL main bearings? My OEM's didn't look like this.
Old Mar 27, 2008 | 10:32 AM
rebo0t's Avatar
did you check the clearances or you just put on the bearings and spun the crank? you need to check either with a bore gauge or plastigauge. also make sure you lube with assmb. lube before turning that crank over.
GReddy SI
Jun 6, 2012 09:31 PM
Riceboy891
Aug 4, 2005 05:11 AM
hondaeg8
May 1, 2005 12:15 AM
B18EG6
Aug 3, 2003 01:19 PM
