arp rod bolt tq???
Old Mar 24, 2008 | 02:17 PM
blackeg's Avatar
Default arp rod bolt tq???
im using eagle ls rods with the newer arp bolts along with an ls crank in my gsr block. the motor will rev to 9000.
the helms has the tq specs on the rod bolts at like 23 for ls and 30 something for gsr. should i use the ls tq spec or the gsr one considering the revs on the motor (400hp turbo car btw).
also, engine oil or moly lube on the bolts?
Old Mar 24, 2008 | 03:02 PM
Lubo_25's Avatar
Default Re: arp rod bolt tq??? (blackeg)
if the rods have arp rod bolts you use the torque specs outlined within the spec sheet...and you use the lube supplied with the rod bolts...for my stock rebuilds i use motor oil but everyone has their own preference...
Old Mar 25, 2008 | 02:59 PM
blackeg's Avatar
Default Re: arp rod bolt tq??? (Lubo_25)
does arp or eagle have a recommended tq for thee rod bolts?
Old Mar 26, 2008 | 11:54 AM
Lubo_25's Avatar
arp bolts should include specs like bolt stretch, bolt torque in ft./lbs., bolt grade, bolt diameter, etc...
eagle does not make rod bolts they simply buy to their spec... make sure you know which bolt you have(5/16", 3/8") because they have different stretch tolerances...and a .0001" bore gage would be nice to confirm any out of round and taper
Old Mar 26, 2008 | 02:47 PM
AJxr's Avatar
my eagles came with a little piece of paper that listed the different rod bolts they use and the trq specifcations next to them. i lost the paper already but they were for a d16 anyway.
Old Mar 26, 2008 | 04:55 PM
blackeg's Avatar
Default Re: arp rod bolt tq??? (AJxr)
yeah aj, i dunno where my paper went. ill probably just call eagle, hopefully i dont get stuck on hold lol
C_Rock77
10
Mar 24, 2010 10:15 AM
TheSwift1
Aug 13, 2003 04:18 PM
Scott - 93HB Si
Jul 30, 2003 05:19 AM
ladysman
Mar 21, 2003 12:08 PM
