another "im leaking oil between the head and block" post, need advise!
d16z6
compression solid across all four
replaced distrib. seal and valve cover seal
loosing no coolant, not mixing
not smoking
runs great
i have not replaced the vtec sol. gasket yet. its leaking only on the distrib side. i orginally thought it was just the distr. gasket because the compression came up solid. anyway, its leaking pretty bad. if i clean the area where its leaking and drive ~20 miles, the entire area under the distrib is covered in oil along with the front part of the block where the d16z6 stamp is, all the way to the pan. i lose about .5qt every week. I really dont want to pull the head but if thats the only thing left then i guess i will/ any suggestions? TIA
not smoking
runs great
Re: another "im leaking oil between the head and block" post, need advise! (1CiViC1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1CiViC1 »</TD></TR><TR><TD CLASS="quote">... i have not replaced the vtec sol. gasket yet...</TD></TR></TABLE>Why not? And the gasket between the spool valve & the head also.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jimmy »</TD></TR><TR><TD CLASS="quote">Cam seal?</TD></TR></TABLE>oops. not on a D16Z6?
I'd consider those before pulling the head.
Modified by JimBlake at 3:27 PM 7/26/2004
Re: (Jimmy)
on a single cam??? d16z6
im going to get the vtec sol. gasket on wednesday...
Re: (Jimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jimmy »</TD></TR><TR><TD CLASS="quote">Uhh yes d-series have cam seals.
Not on the end where he is complaining about oil leaking from.
93grayeg
09-24-2018 03:46 PM
TallAssFilipino
12
09-19-2004 06:23 PM
