Oil leaking somewhere between head and block...
Old 09-14-2004, 01:57 PM
TallAssFilipino's Avatar
Default Oil leaking somewhere between head and block...
Okay. I have oil that seems to always be leaking from somewhere around the top of the block. Well, between the head and the block on the left side. Oil is always around the block and tranny, all over the front wheel-well, and all under the front swaybars to undercarriage. It's really annoying to always have to clean that. I'm going to be taking the engine out and building it up slowly. Nothing too wild. Just a mild build. But during the course of the build-up, I wanted to know some pointers from you guys on what I should look for to change/replace. Thanks in advance.
Old 09-14-2004, 01:59 PM
Unceasing Measure
Archidictus's Avatar
Default Re: Oil leaking somewhere between head and block... (TallAssFilipino)
Every single gasket and, if necessary, machine plug.
Old 09-14-2004, 02:02 PM
Default Re: Oil leaking somewhere between head and block... (Archidictus)
Every single rubber gasket there was to replace, I replaced already. So, I guess that just leaves the machine plug to be replaced?
Old 09-14-2004, 02:03 PM
Risky Business
BauleyCivic's Avatar
distributor o-ring, valve cover gasket, head gasket, vtec solenoid gaskets
Old 09-14-2004, 02:07 PM
Unceasing Measure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TallAssFilipino &raquo;</TD></TR><TR><TD CLASS="quote">Every single rubber gasket there was to replace, I replaced already. So, I guess that just leaves the machine plug to be replaced?</TD></TR></TABLE>
The machine plug(s) I refer to are the frieze (spelling?) plugs that block off oil and coolant passageways in the block and head. They can be tapped for pressure lines, extraneous gauges, etc., and you have at least three of them (2 coolant, 1 oil). One oil and one coolant plug sit below the distributor on the head and the other coolant one, to my knowledge is in the back of the block.
Old 09-14-2004, 02:09 PM
globlctzn's Avatar
http://www.inlinefour.com/topgaskit.html
http://www.inlinefour.com/botgaskit.html
http://www.inlinefour.com/camseals.html
http://www.inlinefour.com/frontmainseals.html
Old 09-14-2004, 02:13 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">
The machine plug(s) I refer to are the frieze (spelling?) plugs that block off oil and coolant passageways in the block and head. They can be tapped for pressure lines, extraneous gauges, etc., and you have at least three of them (2 coolant, 1 oil). One oil and one coolant plug sit below the distributor on the head and the other coolant one, to my knowledge is in the back of the block.</TD></TR></TABLE>
Are they called an oil jet by any chance or am I thinking about something else? I'll keep an eye on it once I get there. Thanks though.
Old 09-14-2004, 02:14 PM
Risky Business
Are they called an oil jet by any chance or am I thinking about something else? I'll keep an eye on it once I get there. Thanks though.</TD></TR></TABLE>
No, oil jet is wedged vertically into the block between the block and the head.
Old 09-14-2004, 02:16 PM
Default Re: Oil leaking somewhere between head and block... (globlctzn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by globlctzn &raquo;</TD></TR><TR><TD CLASS="quote">http://www.inlinefour.com/topgaskit.html
All that's been replaced already except for the intake/exhaust mani' gaskets.
Old 09-14-2004, 02:17 PM
Default Re: Oil leaking somewhere between head and block... (BauleyCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic &raquo;</TD></TR><TR><TD CLASS="quote">
No, oil jet is wedged vertically into the block between the block and the head.</TD></TR></TABLE>
Yeah, that's the exact part I was thinking of. I've only seen them in the SOHC. Where would they be on the DOHC? B-series.
Old 09-14-2004, 02:22 PM
mrnice1058's Avatar
check your valve cover gasket
Old 09-14-2004, 02:39 PM
Default Re: Oil leaking somewhere between head and block... (mrnice1058)
That's been replaced too. And no oil seems to be leaking from that high up on the motor. Mostly around the head-to-block area as far as I can see. I hear some ppl say to check the head gasket, but can oil really be leaking from there and the engine still running nice and smooth?
Old 09-19-2004, 06:23 PM
After taking the engine out this weekend, I finally had a better look at the engine (distributor side). When I had to take the distributor off because of the chains from the engine leveler hitting into it, I saw that the o-ring cracked/split. Odd, especially since it was replaced not too long ago. I hope that's all the oil problem was and nothing more.
mijos
09-05-2020 05:56 PM
hatchet_honda
05-16-2009 02:28 PM
pooRmansss
02-19-2009 03:24 PM
JDMlyfestyle
28
07-20-2006 04:20 PM
12secB18acivic
11-24-2002 10:58 PM
Quick Reply: Oil leaking somewhere between head and block...
