aem cai intake help
Old Apr 14, 2003 | 01:50 PM
cichlid's Avatar
Default aem cai intake help
well i cut it for a bypass valve but decided i didnt want it so i ordered the silicon connector. in ther mean time i used just one piece of it so it was basically like a short ram. today i got the connector and put it on so now i have a cai. well it drove like **** and had less power than the stock airbox and my car died when at a stop. the short ram drove fine. what could my problem be im guessing it is not related to the intake itself but i could be wrong. help please
Old Apr 14, 2003 | 01:54 PM
cichlid's Avatar
Default Re: aem cai intake help (integra121083)
Old Apr 14, 2003 | 02:04 PM
cichlid's Avatar
anyone have any ideas of what it could be? wrong air/fuel mixture? timing? something else?
Old Apr 14, 2003 | 05:27 PM
VTECorona's Avatar
I doubt this is it but disconnect your battery or ECU fuse for 10 minutes to allow it to reset itself then start it up and let it idle for 5 or so minutes and take it for a spin.
If your disconnecting your battery make sure you have your stereo security code handy.
Old Apr 14, 2003 | 05:32 PM
cichlid's Avatar
Default Re: aem cai intake help (97RedTegGSR)
i just took off the a piece of my intake to make it into a short ram and now once again it has more power than with the cold air. ??????????
Old Apr 14, 2003 | 06:18 PM
DK4200's Avatar
you should notice more power w/ cold air... check all connections and reset ecu
Old Apr 14, 2003 | 06:19 PM
VTECorona's Avatar
Default Re: aem cai intake help (DK4200)
Is it a dramatic difference or is it loss of power in only a specific RPM range? If so then that is expected with a CAI, your top-end should be alot nicer though.
Old Apr 14, 2003 | 06:54 PM
cichlid's Avatar
i checked all my connections i think. no it is a dramatic difference. i have it cut for a bypass valve like said before. just a little while ago i took off one piece off it and made it into a short ram and that has more power than the cold air. the only other mod i have is a 5zigen fireball axle back. and now it is making a crackling, popping noise when i accelerate. this doesn't happen when i decelerate or downshift though??????
Old Apr 14, 2003 | 07:48 PM
MikeMAN's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra121083 &raquo;</TD></TR><TR><TD CLASS="quote">i checked all my connections i think. no it is a dramatic difference. i have it cut for a bypass valve like said before. just a little while ago i took off one piece off it and made it into a short ram and that has more power than the cold air. the only other mod i have is a 5zigen fireball axle back. and now it is making a crackling, popping noise when i accelerate. this doesn't happen when i decelerate or downshift though??????</TD></TR></TABLE>
did u recently wash ur car or get any water in anything?
mike
Old Apr 14, 2003 | 08:41 PM
cichlid's Avatar
Default Re: aem cai intake help (MikeMAN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MikeMAN &raquo;</TD></TR><TR><TD CLASS="quote">
mike</TD></TR></TABLE>
NO
what else could it possibly be?
Old Apr 14, 2003 | 08:57 PM
RCautoworks's Avatar
When you made it into a cold air intake, did you put the one silicone piece on well. Make sure it was not leaking there.
Old Apr 14, 2003 | 09:01 PM
cichlid's Avatar
Default Re: aem cai intake help (90blackcrx)
yup
its not the intake its something else but what could it be???????????????
Old Apr 15, 2003 | 11:24 AM
VTECorona's Avatar
It's really weird dude, are you sure your mind isn't playing tricks with you? Check to see if you have a good seal where you took out the bypass valve. Other than that there is really nothing that would be taking away hp from your motor.
Old Apr 15, 2003 | 12:21 PM
cichlid's Avatar
yeah im positve there is a power loss, no question. i checked all of my connections. im getting eng code 73-random misfire?????????????????????
Old Apr 15, 2003 | 04:02 PM
VTECorona's Avatar
Only when you have the CAI portion attached?
Old Apr 15, 2003 | 05:13 PM
cichlid's Avatar
no it does it with the cold air and with just one piece which is basically a short ram. but it is much worse with the cold air??????????
Old Apr 16, 2003 | 10:52 AM
nsxblueteg's Avatar
Do you still get the code when you are running the ram air.
Old Apr 16, 2003 | 11:07 AM
PsychO's Avatar
Default Re: (nsxblueteg)
After you cut the pipe, did u clean the metal shavings off of it?
kseriesDC5
Feb 27, 2004 08:57 PM
Skunk_it
Oct 6, 2002 11:56 AM
94integrals
Sep 3, 2002 04:52 PM
2000GSR
Apr 22, 2002 12:19 AM
lil russia17
Aug 16, 2001 01:32 AM
