ACT vs Clutchmaster
Old Feb 17, 2003 | 06:24 AM
clemsonhatch's Avatar
Default ACT vs Clutchmaster
Did a search of the title and some WTB came up...so your opinions would help!
I have an LS motor that is soon to be boosted.
I have a Clutchmaster stage 3 clutch and flywheel...it's my third set. For some reason I keep getting the defective ones. The first and second set chattered BAD! Now on the third set there is some kind of defect on the flywheel that when it stops in a certain postion the starter won't engage, I have to push the car and dump the clutch to move the flywheel a little and it starts fine. It does it about 5-10% of the time and usually if front of a bunch of people The thing is otherwise this clutch grabs great no chatter.
Is anyone else having problems with these clutches?
Is ACT better?
What would you recomend?
I'm thinking on trying an ACT Xtreme PP & hybrid street disc with the ACT 8.8lb flywheel.
Old Feb 17, 2003 | 07:13 AM
TimoneX's Avatar
New User
Default Re: ACT vs Clutchmaster (wot93hatch)
Your flywheel &/or starter motor teeth are damaged. If you're happy with the clutch and it still has lotsa life, then just change the flywheel &/or starter. I'm using the Action segmented kevlar clutch and Fidanza fly and couldn't be more delighted, though I've only put 700 or so miles on the car with this setup.
Old Feb 17, 2003 | 12:42 PM
joe_bocc's Avatar
I think it's more than a quincedence(sp?) that your having this much trouble with your clutch discs. Perhaps they're not being installed properly or your not breaking in your clutch disc properly.
Old Feb 17, 2003 | 01:39 PM
riceboyEFsi's Avatar
clutchmaster stage 4 ownz , best clutch i ever had 4 puck with springs cant beat it
Old Feb 17, 2003 | 08:57 PM
137's Avatar
137
Default Re: ACT vs Clutchmaster (riceboyEFsi)
I have a civic si and i changed the clutch to a stage 3 kit from cm a while back at 88k... and after 3k of break in miles i owned that clutch, ive broken one motor mount, many numerous bolts have fallen off the engine... it grabs hard and skips gears up to 4th.
Old Feb 17, 2003 | 10:04 PM
SiR-DC2's Avatar
Default Re: ACT vs Clutchmaster (137)
a CM stg 3 is an aggresive clutch. Mine chatters, get used to it, you didn't get defective clutchs most likely you just weren't used to it. You don't know chatter until you have a 6 puck sprung cable clutch...the whole front end shakes...chatter is okay. Have you ever burned a cm? your only complaint it 'chatter'?
Old Feb 17, 2003 | 10:28 PM
yes it takes some getting used 2 , i feel the stage 4 is the best because of previous experience w my old car a gsr swapped hatch i had the cm stage 5. I loved it but it was to much and i drove my friends gsr swapped hf w/ act 6 puck and it was more aggressive than the cm stage 5 and like siR said u really have to burn w/ those style clutches
Old Feb 21, 2003 | 05:04 AM
The stage 3 that's in there does not chatter it grabs fine...I'm very used to it, it chirps third when needed. The problem is that some of the teeth on the flywheel are messed up and the starter won't engage 5-10% of the time. It's embarassing to go to your car in a crowded parking lot and it won't start, I have to push it ghetto style and everyone has a laugh on my expense I have the same clutch and flywheel in my wifes GS-R Her clutch is great. Other than that it feels spongy sometimes? I won the local auto-x in her car with a set of Victoracers a friend let me borrow!
My good friend (Honda Joe) who works at honda and has a lift in his garage is the one that helps put in the clutch...I have had to drop the tranny 3 times it's getting old.
My new ACT clutch and flywheel arrived yesterday and it's going in tomorrow, along with a HaSport rear motor mount (to reduce or eliminate wheel hop!). I'll keep you posted on the difference between the clutches. I have never driven an ACT clutch...but I hear that they're the shi@t!
Old Feb 21, 2003 | 06:26 AM
DC2Slow's Avatar
Default Re: ACT vs Clutchmaster (clemsonhatch)
i have a ACT Xtreme pressure plate Street organic modified disc and a Streetlite 12.5lb chromoly flywheel.
[Modified by DC2Slow, 3:47 PM 2/21/2003]
Old Feb 26, 2003 | 04:35 AM
Default Re: ACT vs Clutchmaster (DC2Slow)
ACT clutch and flywheel in!!! It finally feels like it should!
f150harleytruck7
35
Dec 16, 2005 09:26 PM
allstockb18c
Jul 3, 2005 12:44 PM
nY's FiNeSt
Jan 28, 2004 07:55 AM
Solipsist
Dec 6, 2002 11:49 AM
UNDER PRESSURE
Nov 8, 2002 08:10 AM
