accord basic internal
Old Dec 8, 2006 | 09:49 AM
soon2bdropped's Avatar
Default accord basic internal
i have a 95 accord ex single cam vtec. f22b1
okay.. i understand how a basic internal engine work. but i was thinking.. that since i have one camshaft.. when the camshaft spin. the lobes hit the rocker arm to open the valve.. does all 4 cylinder gets air in at the same time..
for instance cylinder 1 and 4 works together.. when the cam spins it lets air into cyl 1 and 4.. now when it spins again.. does it hits the exhaust valve to open? than when it spins again it does the same for cyl 2 and 3?
kinda confused lol
Old Dec 8, 2006 | 02:46 PM
Default Re: accord basic internal (soon2bdropped)
ttt
Old Dec 8, 2006 | 06:00 PM
02 accord's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soon2bdropped &raquo;</TD></TR><TR><TD CLASS="quote">when the camshaft spin. the lobes hit the rocker arm to open the valve.. does all 4 cylinder gets air in at the same time..</TD></TR></TABLE>
Think about this. If all 4 cylinders got air at the same time and fired at the same time, the engine would jerk once every 2 revolutions. Does your engine run like this or is it smooth?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">for instance cylinder 1 and 4 works together.. when the cam spins it lets air into cyl 1 and 4.. now when it spins again.. does it hits the exhaust valve to open? than when it spins again it does the same for cyl 2 and 3?</TD></TR></TABLE>
Just because cyl 1 and 4 move together, doesn't mean that they are on the same cycle. When cyl 1 is getting air, cyl 4 is firing (both moving down). On the up stroke, cyl 2 is compressing while cyl 3 is getting rid of gasses. The cylinder numbers depend on the firing order, which I don't know off the top of my head, but that's the general idea: the cylinders alternate, and a cylinder fires every 1/2 revolution of the crank.
Old Dec 8, 2006 | 07:34 PM
Default Re: accord basic internal (02 accord)
hmm thats not how it shows on howstuffworks.com this single cam is messing up my theory. anyone else knows?
Old Dec 9, 2006 | 08:36 AM
bump
Old Dec 9, 2006 | 09:08 PM
anyone else know the theory behind all of this?
Old Dec 11, 2006 | 08:14 PM
bump
Old Dec 11, 2006 | 09:37 PM
BuddhaSiR's Avatar
Yes you have one camshaft, but that one camshaft have several lobes. Each cylinder has 4 valves. Each valve has its own lobe. 02 accord is correct. Re-read what he is saying. Firing order on most 4 cylinders is 1-3-4-2. Cylinder 1 fires, then 4, then 3,and then 2. Not a very good explanation, someone help this guy out.
Old Dec 11, 2006 | 09:44 PM
Default Re: accord basic internal (BuddhaSiR)
all i need to know when cyl 1 fires what are the rest of the cylinders doing? just moving up and down until combustion for cyl 1 is made than moves on to the next cyl?
Old Dec 12, 2006 | 08:53 AM
dognutz's Avatar
When cyl 1 is getting air, cyl 4 is firing (both moving down) , cyl 2 is compressing, cyl 3 is getting rid of gasses (both moving up).X2
( basic idea) Its not like they each go through the cycle independently. With each finishing 4 strokes before the next one begins its cycle. The cylinders work simultaneously and in conjunction to produce power.
It takes four strokes, 2 down and 2 up to make 1 power stroke per cylinder (4 stroke engine). So each cylinder is at different place in that sequence of 4 strokes, so there is a combustion stroke every 90 degrees I4 (in line 4 cylinder)gets 360(circle)/4=90 degrees. Think of the crank and the cam as circles. That's why more pistons makes the engine run smoother. V8 gets 360(Circle) /8= 45 so you get a power stroke every 45 degrees of crank rotation.
Old Dec 12, 2006 | 09:29 AM
02 accord's Avatar
Default Re: accord basic internal (dognutz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dognutz &raquo;</TD></TR><TR><TD CLASS="quote">It takes four strokes, 2 down and 2 up to make 1 power stroke per cylinder.....so there is a combustion stroke every 90 degrees I4 (in line 4 cylinder)gets 360(circle)/4=90 degrees.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dognutz &raquo;</TD></TR><TR><TD CLASS="quote">V8 gets 360(Circle) /8= 45 so you get a power stroke every 45 degrees of crank rotation.</TD></TR></TABLE>
You said it yourself: 4 strokes for each power stroke, and that equals 2 crank rotations (720 degrees and not 360).
Actually, it's once every 180 degrees for a 4 cyl and once every 90 degrees for a V8.
Here's a summary..............cylinders
crank position.............1.................2.......... ........3..............4
0 degrees..................firing......exhaust...... ..compression.......intake
180 degrees.............exhaust.....intake............ ...firing.........compression
360 degrees.............intake....compression........e xhaust.........firing
520 degrees.......compression.....firing.............. .intake...........exhaust
720 (2 rotations) it repeats, so 1 is firing again
Edited firing order and made graph easier to read
Modified by 02 accord at 4:05 PM 12/12/2006
Modified by 02 accord at 4:07 PM 12/12/2006
Old Dec 12, 2006 | 08:54 PM
coo anymore theory?
Old Dec 13, 2006 | 06:38 AM
02 accord's Avatar
What else do you want? That's all the theory there is.
Old Dec 13, 2006 | 07:58 AM
dognutz's Avatar
I stand corrected. TY.
Old Dec 13, 2006 | 10:08 PM
cool.. i understand..
t4wrench
Engine Management and Tuning
Nov 20, 2018 04:54 PM
t4wrench
Nov 19, 2018 12:03 PM
barrera
Jan 6, 2010 08:57 AM
dtyst
Mar 23, 2004 11:11 AM
learning honda 2001
Jul 19, 2001 11:07 AM
