98 integra gsr code 45 help please
Old May 2, 2011 | 02:00 PM
allmotorgsr98's Avatar
Default 98 integra gsr code 45 help please
My gsr is throwing code 45 please help me out someone it getting annoying.
Okay this is how it happen when i change my 65mm throttlebody back to a stock gsr throttlebody and started the car then it just hesitate and bogging with mis firing problem when im driving the car around, on cold start there will be black smoke coming out the exhaust and it smell bad not sure what wrong if anyone have this problem before lmk thank
One think i just change the primary 02 sensor already but still have the same problem not sure what is wrong> HELP PLEASE
Old May 2, 2011 | 02:05 PM
frankenghia's Avatar
Default Re: 98 integra gsr code 45 help please
did you plug the map sensor into the tps and the tps into the map? Just a thought....
Old May 2, 2011 | 02:07 PM
I dont think i do that i sure i got it write but ill check tho
Old May 2, 2011 | 02:09 PM
no i got it rite the tps is short too and it wont be able to reach to the mapsensor plug
Old May 2, 2011 | 02:10 PM
correct me if I am wrong but they look the exact same.
Old May 2, 2011 | 02:13 PM
ya they look the same
Old May 2, 2011 | 02:14 PM
Did you calibrate the tps?
Old May 2, 2011 | 02:15 PM
what u think is the throttle body ??? it was fine wit the 65mm no problem
Old May 2, 2011 | 02:17 PM
I think you may need to check the tps calibration on the tb you just put on. It could be way out of spec which would cause you to hesitate, surge, run rich, lean, etc... Also, are you running a tuned ecu or stock?
Old May 2, 2011 | 02:25 PM
oh yeah stock ecu and tps on throttlebody never takin off everthing is stock but just a cold air intake and skunk 2 manifold i pass smog before with those and change to 65mm after that now i need smog again then this happen when i put the gsr throttlebody back on
Old May 2, 2011 | 02:30 PM
Check the calibration. Also make sure you have no vacuum leaks.
Old May 2, 2011 | 02:47 PM
I got a volt meter but not sure how to check tps I think it might be my map sensor I got 2 but I used both and I ask my friend to give me his to test could it be fuel I Hector by any chance ?? Or distributor cap and rotor since I haven't change those but it was weird cux it was fine wit the 65 mm throttle but I noctice that the 65mm do have map sensor to place on but there is no hole throught it to the manifold weird it like a block off map sensor.
Old May 2, 2011 | 02:58 PM
if it runs with the 65mm but not the gsr one then it has to do with something on the tb and or its sensors. Im not Hector by the way if thats what u were asking.
Old May 2, 2011 | 03:07 PM
so you have a pic of the gsr tb? With the "block off"?
Old May 2, 2011 | 03:26 PM
Yea I could get pic for u not now tho I'm at work damn if I don't work I'll beat up that throttle body lol stupid yea it is block but there is a very small hoe u can't even c if the light don't goes shine in it I'll b a soon I'll give u pic and work on that crap throttle
Old May 2, 2011 | 03:28 PM
how does the map location and hole size look on the 65mm compared to the gsr one?
Old May 2, 2011 | 05:06 PM
They look the same but the 65mm have just a small hole to the manifold size I need to show pic what I mean it the same compare to the stock just no hole going toward the back of the throttle body oh yea no Hector I mean injector lol but any way would it be my throttle body gasket that cause it cux I didn't change the thorttle body gasket I have one but it for my new 65mm power throttle body that I was saving it for later when I boost.
Old May 2, 2011 | 05:27 PM
Forgot to mention I have two stock gsr throttlebody when I install same issues happen I think I might try putting the 65mm back on Just for a test to c how it react
Old May 2, 2011 | 11:45 PM
anybody know help me out
Old May 3, 2011 | 08:10 AM
mouab18c1's Avatar
Code 45, fuel system too rich or too lean.
Any CEL?
Trying putting a new stock gsr TB gasket on there as well.
Old May 3, 2011 | 10:41 AM
K got new throttle body gasket sounds better but there still backfire not sure if that's okay cuz I got skunk2 exhaust on it too I'll keep driving to c if the cel come back since I reset it
Old May 3, 2011 | 09:52 PM
mouab18c1's Avatar
I would change out your spark plugs and wires as well if you have not done it for awhile.
Old May 3, 2011 | 11:32 PM
yeah true ill check the spark plug and wire tomm it good to try it out thank for the tip ill let u know if it fix it
StrokeDC2
Sep 20, 2012 05:50 PM
HarosGSRek
15
Nov 27, 2009 07:22 PM
crashsvg
Oct 27, 2008 02:57 PM
Sanda1s
May 23, 2006 09:42 PM
kagegod
Aug 16, 2004 07:59 PM
