97 Prelude: Injectors not firing. Experts help please!
Old 05-06-2007, 11:45 PM
qksl2's Avatar
Default 97 Prelude: Injectors not firing. Experts help please!
So we've got this stockish 97 prelude together. It had a blown head gasket so we replaced that, the water pump, timing belt etc.
Everything seemed fine but spark is intermitant(sp?) and the fuel injectors are not firing. Yes, we've checked EVERY fuse and connection about a million times: three days straight. We've verified continuity between the wires going from the ECU to the injectors. We've got spark "some" of the time. We've check the dizzy many times. The Main relay clicks and primes the fuel pump for 2 seconds; then turns off as it should (my understanding anyways).
The grounds for the PGMfi by the water outlet are grounded to a small bolt there. The main power/grounds off the battery are attatched and tightened. The ECU is not grounding the injectors circuits while cranking, preventing it from starting, and the fuel pump doesn't stay on during cranking either!
Help!
Thanks so much for any advice!
Ian
Old 03-16-2010, 12:16 PM
jonbar87's Avatar
Default Re: 97 Prelude: Injectors not firing. Experts help please!
i've got a similar problem...anyone??
Old 03-16-2010, 12:32 PM
delsolproblems's Avatar
If it's not the connections or the distributor then I think it would have to be a bad ECU.
Old 03-16-2010, 03:28 PM
jonbar87's Avatar
Yes, checked all connections. ECU was working fine before the engine swap. I was actually running an AEM ECU, but since that wouldn't even make the plugs spark, I swapped it out for the known good stock ECU. The stock ECU does make the plugs spark, but the engine absolutely will not start. It'll *almost* start for about a second, then it'll die. Because it seemed as if it wasn't getting any fuel, I plugged a wideband into the secondary O2 sensor port and, while cranking, it read full lean. Because that told me that fuel wasn't making it into the engine, I then took the fuel rail off...good pressure up to the injectors. (gas squirted all over, going to do a fuel pressure check tonight) I then cycled the engine over with the injectors removed from the engine but still plugged into the fuel rail but no fuel squirted out. All the injector connectors are connected properly, so what else could it be?? I'm pretty sure the chance of ALL the injectors failing at once are pretty slim so that tells me it's gotta be some kind of relay or fuse not making the injectors pulse? What drives the injectors/makes them fire? Is there a way to test them? I'm using the stock OBD2 high impedence peak and hold injectors. What about a FPR...do they go bad? I've never been more stumped over a problem than this one here...
Old 03-16-2010, 07:14 PM
jonbar87's Avatar
anyone...?
Old 03-16-2010, 07:54 PM
Sorry man but I was addressing mister Ian. If you post the information about your problem in a separate thread, I'm sure you'll get some good replies. Be sure to make a title that says as much about the problem as possible.
Old 03-16-2010, 08:06 PM
carvers's Avatar
find a buddy with a another h22, and try his dizzy and ecu on your car. did it on mine and it resolved the problem fast compared to the way your going about it.
also you could have installed peak and hold injectors which need resistor boxes or vise versa with saturated.
Old 03-17-2010, 04:06 AM
jonbar87's Avatar
He made this thread in 2007 so I doubt he minds...I just searched and found this thread so thought i might as well just use it...I'm not one of those newbs who makes a new thread for every problem...i just figured I'd bring this one back....
anyway, carvers that's a good idea but I don't know anyone with a prelude.
I'm sure I installed OBD2 high impedance saturated injectors (tried installing an obd1 injector plug onto one just to be sure, and it didn't fit)
basically, i have to figure out why in the world the injectors are not spraying. So far I've come to the conclusion it's got to either be
FPR
Fuel Filter
Low fuel pressure (due to one of the above, or a bad fuel pump)
Main relay
MAYBE a CPS/TDC sensor (although I'm not getting any CEL)
Old 03-17-2010, 08:10 PM
carvers's Avatar
no one runs h series out in AR?
but for the injector clip, there is a little tab on either the injector or the clip that you cut off with a razor and they will fit.
tap the relay while you try starting it.
fuel filter needs to be changed anyways probably
Old 01-31-2013, 05:56 AM
FOXxX's Avatar
Ressurecting this post... describes my problem to a T. Has anyone got an answer for this?
Old 04-21-2016, 12:18 PM
Preludeadam97's Avatar
I am having this problem on mine, any help fellas??
Old 04-21-2016, 12:28 PM
fcm
Old Fart
fcm's Avatar
Dead tread. 94
Old 04-25-2016, 05:33 PM
FOXxX's Avatar
So what ended up being the issue was the main wiring harness connector. The pin that supplied the power to the injectors was missing out of the harness and was not getting proper power to the injectors. It was the needle in the haystack. Trace your wires and make sure the pins are making contact. Before I found it I would have assumed rolling the vehicle over a cliff!
Old 06-10-2016, 06:11 AM
blkbb6's Avatar
am having the same problem, i get spark, fuel in the rail and none in the combustion chamber, spark plugs are dry, motor was recently rebuild, everything was working before i took it apart.
Old 06-10-2016, 10:54 AM
fcm
Old Fart
fcm's Avatar
Do you have power at the injectors, [lead that is the same color at each injector]? 94
Old 06-13-2016, 03:13 AM
FOXxX's Avatar
Really look into the injector power. At the main wiring harness you've really got to look at those pins... both sides of that connection.
Maurice Howard
07-15-2017 06:03 PM
Preludeadam97
04-23-2016 05:31 PM
roro1
04-11-2016 03:37 AM
oksblue
52
08-03-2011 05:32 AM
qksl2
05-06-2007 01:36 PM
Quick Reply: 97 Prelude: Injectors not firing. Experts help please!
