#3 cyl
Old Dec 1, 2005 | 04:49 PM
hatchbackjdm's Avatar
Default #3 cyl
im just curious, what is it about the no 3 cyl that makes it weaker than the others? im just curious cuz my #3 sleeve popped on my ls-t, and i have seen a million others that have done the same thing.
Modified by hatchbackjdm at 6:45 AM 12/3/2005
Old Dec 1, 2005 | 06:30 PM
any one?
Old Dec 1, 2005 | 06:57 PM
EnzoSpeed's Avatar
Default Re: (hatchbackjdm)
It runs hotter than the others because it has two combustion events occuring on either side.
The ignition sequence is:
1-3-4-2
So when you view the cylinders:
1-2-3-4
You can see why #3 runs hot. After it fires, #4 fires directly to it's right, then #2 fires directly to the left. This keeps the cylinder hot which means it's more prone to detonation on the next cycle which means it's more succeptible to a cracked sleeve.
The #2 cylinder runs the second hottest. After it fires, #1 fires directly to it's left, then #3 fires directly to the right.
Old Dec 2, 2005 | 07:59 PM
brian estrada's Avatar
So, basically this is a heat problem rather than a pressure problem?
Modified by savingthecity at 2:35 PM 12/3/2005
Old Dec 2, 2005 | 08:24 PM
EnzoSpeed's Avatar
Default Re: (savingthecity)
Yep. Extra heat causes detonation. Detonation blows sleeves.
Old Dec 2, 2005 | 09:43 PM
but my car never once detonated. i kno that ls stock internals are good to about 250 hp and the sleeves are good to about 300, and i was making 238 hp and 200 tq at the wheels so i should have been well within the "margin" as far as the sleeves go.
Old Dec 2, 2005 | 09:53 PM
EnzoSpeed's Avatar
Right, well with a good tune, the sleeves will hold 400hp. But they won't hold 238 when you're detonating.
Where were you when the sleeve blew? Dyno/track/street?
Old Dec 2, 2005 | 10:06 PM
on the street. i had been in it a lil bit probably 30 - 60 3 or 4 times a couploe min before this happened but i was cruising about 60 in 5th when it finally gave out totally
Old Dec 2, 2005 | 10:07 PM
i am mos def going with water injection when it goes back together
Old Dec 2, 2005 | 10:17 PM
EnzoSpeed's Avatar
Either way, it had to be detonation. Nothing else will destroy a sleeve like that at such a low power level.
Old Dec 4, 2005 | 12:15 PM
743power's Avatar
Default Re: (EnzoSpeed)
how do you know it "never detonated"
do you have a stethescope attached to your block while you are driving? electronic knock guard?
Old Dec 4, 2005 | 08:42 PM
Default Re: (743power)
ok im sorry, i never heard it "ping" or anything else. i just assume that it didnt. if i used a stock sleeved bock and used an alcohol or water injection system would i be ok at this hp level? i plan on building a motor to put in here, but i need something to get me by till then.
Old Dec 4, 2005 | 10:03 PM
EnzoSpeed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchbackjdm &raquo;</TD></TR><TR><TD CLASS="quote">ok im sorry, i never heard it "ping" or anything else. i just assume that it didnt. if i used a stock sleeved bock and used an alcohol or water injection system would i be ok at this hp level? i plan on building a motor to put in here, but i need something to get me by till then.</TD></TR></TABLE>
You didn't hear it, that's all.
Forget the sleeves and water injection, that won't do anything at 240whp. Just find a better tuner that won't blow up your motor again.
EJ6sedan
Aug 1, 2009 11:59 PM
EH2 on Steelies
Feb 9, 2006 08:16 AM
OldSchoolHatch
24
Jun 6, 2003 08:23 PM
VtecInteg95
Aug 29, 2002 07:16 PM
