1000-1500 rpm "choking"
Old 11-29-2001, 09:35 PM
New User
jdmrealm's Avatar
Default 1000-1500 rpm "choking"
At 1000-1500 rpm my car "chokes" likes its turning on and off...if I give a bit too much gas...its chokes if i dont it doesnt. Im thinking its my distributor cap..either that or plugs and wires right?
Old 11-29-2001, 11:32 PM
New User
Turbohatch's Avatar
Default Re: 1000-1500 rpm "choking" (4g63turbo)
it might be the ecu?? did this problem happen before install of ecu. also check your spark plug wires for the right cylinder match up
Old 11-30-2001, 01:55 AM
New User
Type Goch's Avatar
check for any kinda leaks, and check your TB also.
Old 12-01-2001, 01:48 AM
New User
jdmrealm's Avatar
Default Re: 1000-1500 rpm "choking" (Type Goch)
You guys dont think its from the distributor cap? Its not the ecu cause it JUST started happening.
Old 12-01-2001, 10:58 PM
New User
jdmrealm's Avatar
it could be the sparks too..im going to change the sparks and wires and see if it still does it.
Old 12-02-2001, 05:07 PM
b18b98's Avatar
check your timing also..
Old 12-02-2001, 09:50 PM
Pacman
Guest
Posts: n/a
check Tb Sensor. Any check engine light??
My web page.................http://www.geocities.com/teampacman
TeamPacman...................Marouj
stupid is what stupid does............
WWW.IMPORTBUILDERS.COM
Old 12-10-2001, 01:13 PM
New User
jdmrealm's Avatar
Default Re: 1000-1500 rpm "choking" (Pacman)
No check engine lights...ill check sparks and wires...maybe that will help.
Old 12-12-2001, 10:42 PM
ALLMOTORKING's Avatar
TPS SENSOR
ls_turbo_#97
10-19-2009 02:28 PM
dcsports
12-07-2008 06:54 PM
Downz
02-11-2007 06:52 PM
ED8REX
04-25-2006 09:25 PM
SamC
09-03-2003 06:28 PM
Quick Reply: 1000-1500 rpm "choking"
