1000-1500 rpm "choking"
At 1000-1500 rpm my car "chokes" likes its turning on and off...if I give a bit too much gas...its chokes if i dont it doesnt. Im thinking its my distributor cap..either that or plugs and wires right?
Re: 1000-1500 rpm "choking" (4g63turbo)
it might be the ecu?? did this problem happen before install of ecu. also check your spark plug wires for the right cylinder match up
check for any kinda leaks, and check your TB also.
Re: 1000-1500 rpm "choking" (Type Goch)
You guys dont think its from the distributor cap? Its not the ecu cause it JUST started happening.
it could be the sparks too..im going to change the sparks and wires and see if it still does it.
check your timing also..
check Tb Sensor. Any check engine light??
http://www.accralite.com/accralite/i...iston_spin.gif My web page.................http://www.geocities.com/teampacman TeamPacman...................Marouj stupid is what stupid does............ http://communities.msn.com/_Secure/0...withstupid.gif WWW.IMPORTBUILDERS.COM |
Re: 1000-1500 rpm "choking" (Pacman)
No check engine lights...ill check sparks and wires...maybe that will help.
TPS SENSOR
