1.8 Crank on a 1.6 block..Question
Old May 15, 2003 | 09:39 AM
Rotten Banana's Avatar
Default 1.8 Crank on a 1.6 block..Question
Will a gsr1.8 crank fit on a 1.6 si block. If so will this be beneficial???
Old May 15, 2003 | 11:03 AM
_Not_So_Nice_Guy's Avatar
Default Re: 1.8 Crank on a 1.6 block..Question (Rotten Banana)
yes, but you will need custom rods and pistons to make it work. Beneficial? Yes and No.
Yeah, more torque but crappy R/S ratio, and cost a lot. If you want to go 1.8L, swap the block with it.
Old May 15, 2003 | 12:13 PM
joe_bocc's Avatar
IMO, this would be a terrible engine. You would have something like a 1:1 rod:stroke ratio. Plus custom rods would probably cost a lot.
Old May 15, 2003 | 02:08 PM
QCKGSR's Avatar
Default Re: 1.8 Crank on a 1.6 block..Question (joe_bocc)
a b18c crank in a b16a block?
Old May 15, 2003 | 11:57 PM
4DeepCivic's Avatar
Default Re: 1.8 Crank on a 1.6 block..Question (QCKGSR)
You can get a B17 crank with the stock b17 rods and it works.. B17 is basically a b16 with a b17 crank. just like a B16B and B18C
93xsi
Oct 18, 2010 09:42 AM
Hybridvalve
17
Oct 19, 2009 06:01 PM
Chugger
Mar 3, 2006 01:22 PM
turbotypeR@SPEC
Dec 5, 2004 10:51 AM
DA tegger
Jan 21, 2002 10:53 AM
