B16 FI buildup.. to stroke or not to stroke?
Hey, if i'm building up a b16 and i need to get a crank anyhow, if i got a B17 crank and b17 rods, would it or would it not bolt up to the block with little to no modification? Is this easy or not? Wouldn't it be worth it, since i have to buy a crank anyhow, might as well get the extra cc from the b17 crank right?
yes the B17a crank and rods fit in b16a block, (that is what exactly honda did, b17a is nothing more then b16a with different crank/rods and pistons (lower c/r))
you might want to take a look at buying a b18c block rather then storker kit or new crank....
yes the b17a, combo should gain you extra 53cc more displacement....
