Suspension & Brakes Theory, alignment, spring rates....
DC - EF brake swap
Old 04-17-2010, 09:56 AM
kingsnake692005's Avatar
Icon3 DC - EF brake swap
I am wondering if you can bolt the dc integra rotors, caliper & caliper mounting brakets to an ef front knuckle.. Im also doing the rear disk swap & im swaping the master cylinder, & proportuning valve to do the rear disk swap the correct way.
Im keeping my D motor but I wanna get the aftermarket stock "big brake kit" thats why I needa know if the front brakes will bolt to an ef front knuckle.
Old 04-17-2010, 11:21 PM
roastbeefrichie's Avatar
Default Re: DC - EF brake swap
no, you cannot bolt up the 94-01 integra LS/RS/GS/GSR front caliper & rotors
onto your 88-91 civic EF front knuckle
(unless it is a 90-91 civic EX front knuckle; which accepts 10.3" front rotors, same size as found on any 90-01 integra * excluding ITR)
> if you do not have the 90-91 civic EX front knuckles
then you have 88-91 EF DX knuckles, which use 9.4" front rotors.
here's a few options for upgrades on DX knuckles:
1. www.fastbrakes.com sells a bracket which mounts the DC integra front calipers onto a DX knuckle with a larger rotor set-up.
honda-tech member BE2 specializes in OEM honda brake upgrades kits.
2. here's a link for: s2000 front calipers, which use 11" rotors on a DX knuckle
http://hondamarketplace.com/showthread.php?t=2569691
3. Acura CL brake upgrade for 9.5" Civic Brakes > 11" rotor
http://hondamarketplace.com/showthread.php?t=2756883
Old 04-18-2010, 09:36 AM
could i use ex knuckles off of an eg hatch
Old 04-18-2010, 09:43 AM
92-95 civic EX (or 94-01 integra LS/RS/GS/GSR)
front knuckles are better suited for EG civics
Old 04-18-2010, 12:15 PM
I have an ef/ed hatch & i was wondering if the eg knuckles will fit my hatch
Old 04-18-2010, 02:40 PM
for the best alignment results on any 88-91 civic/CRX EF,
use 90-91 civic EX or 90-93 integra DA front knuckles (complete with calipers)
Originally Posted by BrakeExpert
For those of you with a soggy brake pedal after caliper installation, here is the CORRECT bleeding sequence:
Bleed the brakes Right Rear, Left Front, Left Rear, Right Front. You do not go farthest to closest with Hondas.
Always bench bleed the Master cylinder when replacing the master cylinder, ABS unit, or proportioning valve.
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/da-knuckles-vs-si-knuckles-ex-knuckles-big-brakes-2140287/
Old 04-19-2010, 11:32 AM
eviled's Avatar
s2000 calipers and carriers with 3mm milled off the back on 12" civic type R (ep3) discs on CRX SiR knuckles
Old 04-21-2010, 06:12 AM
99SiStyle's Avatar
I have the DA front brake conversion from fastbrakes, works great!
Old 09-20-2010, 09:55 AM
spoon.ef9's Avatar
anyone got pics to confirm an s2k caliper on an ef(stock cx hub)? And what size rotor from what car?
Old 07-04-2013, 11:58 PM
89ED's Avatar
what if i have 90 lx knuckles on my 90 lx sedan can i do it?
Old 12-17-2013, 09:39 AM
jds400ex's Avatar
I got and 90 ef si that I want swap with dc 4door brakes. I also have tokico struts and neuspeed springs from a 93 del sol that im going tobe putting on. just wondering if all this will work
Kyle.Fitzjearl
09-10-2009 05:30 AM
v-motion
05-24-2008 07:02 AM
trrbl1bmx
07-14-2006 02:59 PM
Nov!ce
12-18-2004 07:26 PM
TypRice
11-23-2003 11:52 AM
Quick Reply: DC - EF brake swap
